Yesterday my volume took a dive, returned but with no treble and after pulling the cables from the loop (only run an eq thats not on and a dd-5 that also was off) everything was ok. After a few minutes of checking the train of pedals I plugged in the loop again and no more issues. I have been having issues with my loop...from it cutting out ( pressumed it was an issue from my boss pedals) and now this. Anyone have any thoughts.
I have a reasonably new mkll rv 50 with stock tubes and you can find pics of my pedalboard if needed recently posted in the pedalboard thread.
thanks for all and any help/
Mike
faulty tube in loop??
Gibson: Angus Young SG 03 / LP Standard 05 / Firebird V 01
Orange: RV50 mkII & ppc212-c / Micro Dark & ppc112 / TH30 Combo
Re: faulty tube in loop??
Hi
Could be anything on the loop...its often a faulty patch lead or cable....I'd suspect these first as you had a problem with the pedals off.
Could also be a pre-amp tube but I would think this would not be intermittent?
Jim Root #4
Cornford RK100 and MK50
Cornford and Trace Elliot cabs
Gibson, Gordon Smith, Musicman, Fender guitars
Tried cleaning all your jack plug connections? (Proper electrical cleaner!) Might not be that, but it's the first thing I'd try myself.
Same can happen with valve connections too. Tiny bit of dirt on one or more pins can cause problems. (Just be careful to line up the pins right when you put a valve back in - never force them!) For valve pins you need to use a NON lubricated electrical contact cleaner. Handy to have both types!
(Which reminds me, that's something for the shopping list... )
Thanks for the input guys!! I switched my cables around going from my pedalboard to my amp and problems solved!!!
Good news....glad you got it sorted fellaMikeD wrote:Thanks for the input guys!! I switched my cables around going from my pedalboard to my amp and problems solved!!!
Jim Root #4
Users browsing this forum: Google [Bot] and 7 guests
