Tone Loss, Need Help
I have an AD30TCH. When I plug one 16ohm PPC212 cabinet into the 16 ohm out, the tone is full and balanced with decent bottom end. When I daisy chain two 16ohm PPC212 cabinets into one 8ohm out, there is a remarkable loss of tone. The two cabs together sound extremly bright with no bottom end whatsoever. I tryed adjusting the eq to make up for this tone loss/change, but that doesn't help. Would any body please explain why this tone loss is happening? Thanks!
the reason as i understand it is as follows:
if you daisy chain the cabinets then each speaker is receiving 1/4th the total watts of the head. so each speaker is seeing 7.5 watts. with just one 2x12 plugged in each speaker is receiving 1/2th the total watts of the head, so 15 watts each. with one 2x12 you are pushing the speakers harder making more bottom end. with 4 speakers you aren't pushing the speakers as hard and losing bottom end.
i'm not 100% sure on this one, i'm just trying to use common sense.
anyone else?
anyone else?
2002 PPC412 (British V30s)
It is a wattage issue. Having 2 2x12 connected to the AD30 you have 240 watts handling on a 30 watt amp.
The speakers will not be driven hard enough to even start breaking up.
It will sound like you changed your pre amp tubes to a low gain.
This will good if you want to use effects to give you distortion, but you speakers wont without.
Why do you need 2 2x12's, one should be fine.
Otherwise get lower wattage speakers that your amp will drive.
sounds to me like the two cabs are out of phase with each other. you get that when the +/- leads are reversed relative to each other. this would be from inconsistent wiring internally. but, to get a real answer rather than guessing, call either Jason or Graham at Orange USA. Very helpful dudes.<font face='Stencil'></font id='Stencil'><font face='Arial'></font id='Arial'>
I'm just poppin' in here, but as far as I can think, it's a Wattage-problem, or maybe the wiring, I don't know enough about that.
but about the "double 4x12" on a AD140 ...
30w -> 240 == 1/8
or
140w -> 480 == 1/3.4
So with 2 4x12's hooked op in daisy chain, there is still a "double" of power hitting the speakers no ... (altough I tought celestion V30's were 70watts ?)
peter
- ORANGE AD200B #083MK2 -
- ORANGE AD140B #006 -
- ORANGE 8x10" BASSCAB -
- ORANGE OD120 #13993 -
www.sixtoys.be
30w -> 240 == 1/8
or
peter
www.sixtoys.be
peter
AD200B-MKII (#083/090) / OBC810 (199x) / OBC410 (2006) / OD120 (1976) / ORANGE 'TOASTER' Micro-amp
bummer iron man, i thought i could pick up your orange equipment for cheap on ebay but.....now that you're problem's solved...just kidding. i also like the idea of the two pp12 cabs, it's a combo i've fantasizing with for some time now and i like your thinking, lighter to move around, cool vibe......just gotta wait to get the spare cash but i'm sure that's where i'm headed too<font face='Arial'></font id='Arial'>
Users browsing this forum: No registered users and 199 guests
