Hey fellow Covidiots!
Can you dudes tell me if this Orange OBC410 cab (2009 Limited Edition, in white tolex) is shot? I recently bought it used and it sounds awesome clean with my matching Terror Bass MKI head, but when I add some overdrive from the amp it sounds godawful almost like it's farting out and crackling!
I inspected the paper diaphragms of the top two speakers and they seem fine, but I can't access the bottom two speaker baskets or inspect any of the cones as I can't see any obvious way to open up the cab.
Anyways, have a listen to this little youtube clip I made - does it sound like a busted cone or something?
https://www.youtube.com/watch?v=5xLVbPiVNZI
Orange OBC410 - is this what a busted speaker cone sounds like?
Re: Orange OBC410 - is this what a busted speaker cone sounds like?
Actually I was able to get the front grille off (it's just attached with velcro, easily pried off with a flat-head screwdriver), and after inspection, all of the speakers seem fine.
There is a small horn in the centre however, I wonder if that's what giving the nasty sound? Is there any way to just turn the horn off completely? This Special Edition OBC410 does not have a Hi/Lo/Off switch on the back for different horn settings. Ideally I'd like to just have the horn off all the time.
Users browsing this forum: No registered users and 279 guests
