Rocker 30 Combo with external cab?
Posted: Fri Oct 04, 2019 7:09 pm
by elvisdog
Contemplating a beat-but-functional Rocker 30 combo, just wondering if it will work with my 16-ohm ppc112 as an extension cabinet. I would like to run both the internal speaker and the ppc112 at the same time to make a big noise. Can't seem to find a manual for the combo anywhere but this will work somehow, won't it?
Re: Rocker 30 Combo with external cab?
Posted: Fri Oct 04, 2019 11:13 pm
by elvisdog
never mind. search solved this question.
Posted: Sat Oct 05, 2019 2:32 pm
by Les Paul Lover
Glad you found the answer already.
Simply plug both 16ohm speakers into the 8ohms taps.
It should sound great. Just so you take that into account, if the combo has been well used, i would plan for some new EL34 too.
The amp is cathode biased, so it's simple swap you can do yourself.
