impedance question
elvisdog
impedance question
Post by elvisdog » Mon Jul 01, 2019 2:30 pm
Hey all, I have a Rockerverb 50 and I'm picking up a PPC 112 today. I wanted to run the amp into the 16-ohm Orange cabinet and an 8-ohm Fane in a second cabinet. The amp has output jacks for both 8 & 16 ohm outputs but will running both at the same time cause problems?
Fane M65 in an open-back single 12 cab is a killer speaker with this amp. I wanted to see how it would pair with a closed-back v30. Playing a lot of outdoor stuff this summer & thinking the two would work well together -- open back for stage sound, closed back for projection and punch. Thoughts?
northernguitarguy
Re: impedance question
Post by northernguitarguy » Mon Jul 01, 2019 3:16 pm
Nope, you shouldn't do that. You can drive a 16 ohm cab OR an 8 ohm cab OR two 16 ohm cabs in the two 8 ohm inputs.
Ddjembe Mutombo
Post by Ddjembe Mutombo » Mon Jul 01, 2019 7:38 pm
Too much is made about mismatched loads. If you run a 8ohm head into a 16 ohm cab it's fine, your tone will just sound a little more compressed.
As far as mismatched cabs. A dozen years ago, accidentally miswired a 212 and ran it with a 412 for years. I think I was running an impedance of 16 on the 4x12 and 32 on the 2x12. None of my heads blew up. I opened it up years later to rewire back to 8 ohms and noticed the error my math caused.
If you've done any circuit work, you'll realize how low of impedance an ohm is. So being off by 4 or 8 ohms isn't going to really kill anything. Yeah, it may tax your amplifier a little more, but most amps can handle it.
Monty
elvisdog
Post by elvisdog » Tue Jul 02, 2019 9:54 pm
went to the source & asked Orange customer service. they said no mixing impedance. they also said that running the rockerverb into a single 1x12 cabinet was a bad idea, though they sort of gave me permission to run at half power.
luckily I have a 16 ohm gold to replace the Fane with, which will give me a safe load.
Post by Jondog » Wed Jul 03, 2019 1:59 am
Strange they told you running a Rockerverb 50 into a 1x12 is a bad idea, unless they were just being cautious because they don’t know what speaker your using. The PPC112 has a 60 watt speaker. Also they sold the Rockerverb 50 as a 1x12 combo.
Ronnie Robinson
Post by Ronnie Robinson » Wed Jul 03, 2019 8:53 pm
My thoughts will be to get a second hand orange open back 212 cab and sell the 112- they are much better cabs for playing live especially outdoors and you could mix your speakers types if you wish.
Orange AD30 HTC
Orange Rocker 15 terror
Orange Tiny Terror HW,
Previously Owned - Rocker 30
Ddjembe Mutombo
Post by Ddjembe Mutombo » Tue Jul 09, 2019 2:56 pm
Odd. Mesa actively encourages impedance mismatching as it provides a slightly different tonality. They also ship the Lonestar classic (100-watt amp) in 1x12 form with a C90 (90-watt speaker).
Monty
northernguitarguy
Post by northernguitarguy » Thu Jul 11, 2019 5:16 pm
MB only 'encourages' mismatching amp ohm output with a speaker double the amp ohms. They do not suggest driving one 16 ohm and one 8 ohm speaker like the OP was asking.
