Hi! I have an OR15 which I love the sound of the gain on. I usually have the gain dialed in around 2'oclock. However, I would like to be able to switch to a clean sound with a switch.
What is a good alternative to the OR15? Something < 50watts would be preferred. Something with a good hard rock / modern sound when boosted.
Thanks!
Two Channel Alternative to OR15
Re: Two Channel Alternative to OR15
Anything from a Rocker 15, 30, or 32. Dual Terror (although not great for clean) TH30, AD30HTC, Rockerverb 50.
For what your describing I personally would go for the AD30HTC or Rocker 30.
Thanks I will check out some demos of those amps. What do you think of the thunderverb 50? It's more wattage than I am looking for but I use a two notes live at home so bedroom volume isn't an issue.
A second OR15 for the clean channel!
I'd love to see a twin channel AD15TC
Is an effects loop important to you?
I think the Rocker 15 / Rocker 15 terror is possibly your best choice, if you want something similar size and price to what you have and has power scaling down to 1/2 watt output
If effects loop not need then Rocker 30 or Ad30 Tc ... Which has lovely cleans
Users browsing this forum: No registered users and 457 guests
