ROCKERVERB MKiii 50 volume loss
stiggamuffin
Post by stiggamuffin » Tue Apr 09, 2019 12:52 pm
I am getting intermitent loss of volume/compression.
I can still hear so it doesnt go completley.
I have had a full service and he couldnt find and issue anyone else experienced this issue
Hubaxe
Orange Expert
Re: ROCKERVERB MKiii 50 volume loss
Post by Hubaxe » Tue Apr 09, 2019 1:33 pm
Stupid question: does that happens only using a trusted cable and a guitar ? (no fancy effects, etc). Just to make sure the cause is the amp and not something else.
stiggamuffin
Post by stiggamuffin » Tue Apr 09, 2019 3:22 pm
ive tried a few ways
and yes i have tried it straight in.
Ive had it a while and not changed any of my set up and it all of a sudden happened
Post by Les Paul Lover » Tue Apr 09, 2019 10:02 pm
Does it happen on both channels?
If you're sure the reason isn't your guitar, your cable, your speaker cable or your speaker cabinet (have you tried the same set up with a different head?), there actually is little you can do yourself beside changing the valves.
You can change the preamp valves yourself, but the EL34 need be biased.
If it isn't the valves, and your tech couldn't trace the issue, you then need a new tech.
Users browsing this forum: No registered users and 16 guests
