Ok, normal apologies if this has all be talked about before but can't really find a definitive answer to my particular configuration. And I just want to be sure.
I have a Dual Terror Head and want to use the PPC112 cabinet + use the speaker in the CR60C stacked (I understand I need a speaker lead extension). Plug into the 2 x 8 ohm outputs of the dual terror head! Correct?
The set up is mainly as a backup at live gigs so I can switch to the CR60C if the dual terror goes kaput.
If I need to use the back-up CR60C, I plug the PPC112 + CR60C speaker into the 2 x 16 ohm speaker outputs from the CR60C. Correct?
Big thanks and hugs in advance.
Dual Terror, PPC112, Crush CR60C configuration
Re: Dual Terror, PPC112, Crush CR60C configuration
Is the CR60 using a 16 ohm speaker?
Sorry didn't make myself clear.... Its the CR60C combo, and the on-board amp is currently connected to one of the two 16 ohm outputs on the back.
You plug two 16ohm cab/speakers into each 8 ohm outputs. Correct. Assuming the CR60’s speaker is 16 ohms.
Thank you, and assuming if I have to use the CR60C backup plan I would plug the onboard speaker into the on-board amp (as shown in my photo) and the PPC112 into the other speaker socket.
I know it all sound rather obvious, but I am always nervous about ohms and stuff like this.
Yes, that's exactly right.sarah1066 wrote: ↑Mon Feb 18, 2019 4:08 pmThank you, and assuming if I have to use the CR60C backup plan I would plug the onboard speaker into the on-board amp (as shown in my photo) and the PPC112 into the other speaker socket.
