Phil,
Nice guitar! You've already confirmed that you are not in any hurry to gut it and I'd say that's sensible!
If you trust your guitar tech and he's not likely to charge huge amounts, I'd still suggest getting them to take a look. The most likely faults are electrical continuity - either a wire isn't connected or it's touching somewhere it shouldn't. It could be a very easy fix to get it back to full operation.
If there is something more significantly wrong then rewiring might be worthwhile but it would be good for you to be more familiar with the guitar's tone before you decide exactly what to do. Higher resistance pots can make the guitar brighter and conversely lower resistance can round off harshness. You will then see lots of talk about 1950s wiring versus "modern". If you don't use the tone controls then it may be that the 50s wiring would be attractive to you...
NGD, but a problem
Re: NGD, but a problem
Thanks PBA, all good suggestions. When he is back, I will get him to just check everything over and I will probably put 010's etc on it. I have 011's at the moment on the other LP's and the Tribute has 009's and it has made me think 010's will be best for me. I will get him to have a look at the electronics and if it is an easy fix then great, if not it can wait. Cheers.
I just thought I would post an update. It’s all fixed, but there were other problems found and rectified by my Luthier/Tech.
• Original problem: treble tone pot did not work at all. The surface mount capacitor circuit board trace was broken. Rectified by hardwiring a 0.22 Cap. Works fine now.
• He also found that there was an earth problem with the pups. I had always thought that it was a lot noisier than my other LP’s, but didn’t really think anything of it. He has rectified it and it is much quieter now.
• The output jack (which is plastic), was very pliable and when extracting the jack, I could sometimes see the plastic plate “puling” so was very careful with it. While not really a problem and I didn’t ask him to look at it, he did and it now has a metal one on it and it is much more robust. I’ve kept the old one in case I sell it.
• He also fitted the poker chip which came with it. I just thought I would mention that.
He’s set it up with 010’s (it came with 009’s) and it plays really nicely. Intonation is spot on, so I am really happy.
I have not named him, so I’m not advertising him, but all that cost me £32 and that included the new set of D’Addario strings, Jack plate, capacitor and set up. Pretty good value wouldn’t you say? He has been in the business a long time and has always been reasonable.
Cheers.
Phil
Cheers.
Phil
Rozz wrote: ↑Wed Sep 12, 2018 11:35 amI just thought I would post an update. It’s all fixed, but there were other problems found and rectified by my Luthier/Tech.
Cheers.
Phil
I love happy endings. Good thing you didn't send it back, you've kept yourself a player.
Yay - Good news.
Sounds like good value too. I don't know the rules on naming him but I suspect other folk in your area may be keen to know of a good, local tech...
Users browsing this forum: Google [Bot] and 284 guests
