OR100 - Ultra noisy FX Loop - four cables method
Posted: Wed Aug 08, 2018 1:07 pm
Hi everyone,
I have been playing on an OR100 for three years now and I always loved that warm vibrating dark sound coming from it. Best amp I ever owned.
I decided to upgrade my gear. I bought the Boss ES-8 switcher that works like a charm and I recently decided to go stereo using my second amp, a Rockerverb combo 50. I then connected the gear after testing all my Evidence audio patches on the pedalboard and everything is in excellent working conditions. I use the four cables method that I extended to my second amp (I never tried the fx loop on the OR100 before nor the Rockerverb).
The connections are in fact a little more complex as the output on the ES-8 go through a Deco pedal (set to stereo using a YPP signal splitter cable) and then through the Loop Station before getting to the amps.
So, after making sure all the cables are connected the correct way (I followed the explanations of an Orange video on YouTube), I turned on both amps and decided to give it a try. MAJOR DISAPOINTMENT!
Here is the result I get:
1- I immediatly notice both amps are very noisy even with all pedals on Off. Major buzz/hiss sound.
2- The volume control on both amps are not working correctly: on the OR100, if I put the volume to zero or higher setting, it does not change anything to the sound. If I turn on the volume on my guitar, then it plays loud, same with my volume pedal (volume is zero on the Amp!). It is like my volume pedal and my guitar are now a bypass over the amp, taking control of it. Not a good thing.
The return on the Rockerverb does not seem to be working as no sound comes out of it. But, if I connect the cable in the front of the amp, then, some sound comes through, but I have to increase the volume to about 50% to match the OR100's volume. And it is very noisy.
The result:
1- Confusion.
2- Not suitable for live or studio.
3- Looks to me like there is something very wrong with the amp (both?).
4- When I connected the traditionnal way (2 cables), I never heard extra noise on the amp even with all pedals in use. In fact, it was very silent, clear music.
Gear:
1- I play a Gibson Les Paul Voodoo and a Gibson Les Paul Black Beauty Custom.
2- I use SIS Evidence Audio as patch on the pedalboard
3- I have three Evidence audio the Forte cables (tons of tone)
4- I also have a Vovox cable.
Questions:
1- Anyone had a similar problem using the fx loop on the Orange amps?
2- Is there a solution to regain control of the amps volume?
3- Can anybody help in any way?
4- I always thought playing stereo using the fx loop on the amp was similar to paradise... For the moment, it is more like hell.
Here is my connection map:
1st cable: Guitar plugged in the ES-8 looper (In1)
2nd cable: SEND VOL on ES-8 goes to front Input on the OR100
3rd cable: SEND from OR100 goes to RETURN VOL on ES-8
4th cable: OUT1/Left on ES-8 goes to Strymon DECO (equiped with YPP splitter - red socket)
5th cable: OUT2/Right on the ES-8 goes to Strymon DECO (YPP splitter black socket)
6th cable: LEFT OUT on DECO goes to INPUT A of Loop Station
7th cable: RIGHT OUT on DECO goes in INPUT B of Loop Station
8th cable: OUTPUT A of Loop Station goes to Return of OR100
9th cable: OUTPUT B of loop station goes to RETURN on Rockerverb 50 (or in the front input of it)
Conclusion:
Please, let me know if you see what is wrong. I really need help. Thank you.
Maika_mb
The result:
1- Confusion.
Gear:
Questions:
Conclusion:
Maika_mb
