I posted about an AD30TC combo I bought recently and it had a nasty sound that I thought was tube vibration, as per the advice here, I replaced the tubes and sure enough it was a microphonic tube.
Now I seem to have another issue with blowing a fuse. I have played it quite a bit and not had any issue and the. I blew both fuses last week. I figured they would possibly be weak since they lived 10 years in a guitar store but I replaced them and played a while, everything was fine until I put it to standby again and flipped back to play and no sound came out again. I checked and it blew a fuse (the one closest to the D plug). I replaced it again and tried and it immediately blew the same fuse.
Any thoughts? Seems like it is popping out of safety as there is a problem elsewhere in the amp, right?
Amp blowing fuses
Amp blowing fuses
Rockerverb 100 MKIII
Rockerverb 50 MKIII combo
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson explorer custom
gibson es355
gibson es359
gibson sg custom
gibson les paul custom
gibson les paul standard
gibson les paul studio
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
Re: Amp blowing fuses
The most common cause of blown fuses in an AD30 would be a bad power tube or bad rectifier tube.
Replace the EL-84's and the GZ34 with trusted tubes. Put new fuses in and try again. This will likely solve the issue. I'm assuming the tube you replaced was a pre-amp tube. If that's not the case, we'll do more trouble shooting.
Stop using the standby switch. From my experience, it leads to premature rectifier tube failure. Leave it in the ON position at all times. The GZ34 is soft start and this will not harm the amp or the tubes.
Yep, sorry to say but most likely a tube (again)
Thanks for the replies. I replaced all of the tubes. Unfortunately I threw the others away so I can’t test out the others. The place I ordered tubes from said to send the ones in question back in to them for testing... kind of an annoying process but likely how I should proceed.
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
One thing I checked on is the fuses I ordered. I ordered the same fuses that was in it but the filament section of the new fuses is extremely thin while the originals are more robust. I am sure I should be using slow blow fuses but i would have thought ordering the same number on the fuse would give me that, no?
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
afjungemann wrote: ↑Thu Jun 21, 2018 1:45 pmOne thing I checked on is the fuses I ordered. I ordered the same fuses that was in it but the filament section of the new fuses is extremely thin while the originals are more robust. I am sure I should be using slow blow fuses but i would have thought ordering the same number on the fuse would give me that, no?
Fuse of the same rating can look different depending on materials used.
The only fuse I've blown on my AD15 was caused by the valve heater system failing. The crappy crimping connectors failed - but that was pretty visible.
All light were off, and only the GZ34 warmed up as it gets its heater supply from a different source.
I've since removed all crimping connectors and hardwired the heater supply to the preamp and power valves.
Users browsing this forum: No registered users and 343 guests
