Rocker Terror 15 head, is it cathode biased ?
Got a pair of matched tung sol el 84s coming next week, can i drop em in without need for rebiasing ?
Fender USA Ash Telecaster
Orange Rocker Terror 15 Head
Sonic Research ST300 turbo tuner
Diamond CPR1 Compressor
TC Electronic Sentry
CAE MC 404 Wah
Catalinbread Talisman Reverb
MXR 234 Analogue Chorus
Naga Viper
Suhr Riot
Zilla 1x12 Cab with Greenback
CAE MC 404 Wah
Naga Viper
Suhr Riot
Re: Rocker Terror 15 head, is it cathode biased ?
Since it is based on the terror platform, and < 50 Orange watts, I would say YES! That said, the manual does talk about "getting a qualified technician to bias". So I have no idea. What a pointless post from me
Let us know how you like the new valves.
What valves came in it originally? I take the valves are not that old?
yeah ive always dug tung sol tubes and the jj's my rocker terror came with will make good spares.
CAE MC 404 Wah
Naga Viper
Suhr Riot
CAE MC 404 Wah
Naga Viper
Suhr Riot
Bump. If anyone has a definite answer to this question I would really appreciate it! The best is have been able to find so far are educated guesses, but not a definitive answer yet. Thanks!
Amps
Orange Rocker 15 Terror
Marshall DSL40C w/ Celestion V30
Vox AC4TV
Guitars
Epiphone Slash Les Paul Standard Plus Top
Yamaha FGX700SC Acoustic/Electric
Pedals
Dunlop CM95 Clyde McCoy Crybaby Wah
Ibanez Tube Screamer Mini
TC Electronic Ditto Looper
Vox AC4TV
Guitars
Pedals
Your amp is cathode biased. Pop those Tungsols in and rock on.
Thanks!
Also, I contacted orange directly, and they confirmed the following: Rocker 15 Terror is a class A amp, and biasing is not necessary when changing the power tubes.
Amps
Vox AC4TV
Guitars
Pedals
Vox AC4TV
Guitars
Pedals
Operating class is independent of biasing method. The amp is cathode biased, therefore the tubes will *usually* drop in and operate without worry.
It is still prudent to keep an eye on them to make sure they are not red plating. That’s a quick and crude method of verification, but likely all you will have (or need) to ensure there aren’t any problems.
And Orange talks the “Class A” marketing game just like everyone else. It’s unlikely the amp is true Class A. But that’s a different discussion! Haha.
Thanks for the info! How do I tell if the tubes are red plating? Like, will they literally be glowing red? And if they do, I should go get the amp biased, even though it is cathode biased? New to the world of tube amps, and thirsty for knowledge, so I really appreciate anything you can teach mefiveightandten wrote: ↑Tue Apr 24, 2018 10:24 pmIt is still prudent to keep an eye on them to make sure they are not red plating.
Amps
Vox AC4TV
Guitars
Pedals
Vox AC4TV
Guitars
Pedals
Every tube set draws a different amount of current. A cathode biased amp will adjust itself over a certain range, but tube sets that draw a lot could potentially run too hot in the amp.dhalaney wrote: ↑Tue Apr 24, 2018 10:35 pmThanks for the info! How do I tell if the tubes are red plating? Like, will they literally be glowing red? And if they do, I should go get the amp biased, even though it is cathode biased? New to the world of tube amps, and thirsty for knowledge, so I really appreciate anything you can teach me
You’re correct, the plates (the big vertical metal pieces) will literally glow cherry red when a tube is running to hot (at that point, it’s way too hot). I’ve had this happen with some tubes sets in my Vox AC-30. This isn’t the small metal filaments that glow whenever the amp is on, it would be the big metal pieces glowing red hot. If this happens, I’d return them and get a new set. You can request lower draw tubes as the replacements. This, IMO, is better than altering the cathode resistor values in the amp (which is how you’d have to adjust the bias).
This is why good tube suppliers will ask you what amp the tubes are going in. They will select a set that will run within spec in the amp. Many EL84 amps are cathode biased.
In all likelihood, whatever tubes you use will be ok. But the misconception that every set runs the same in the amp isn’t true. I’ve had plenty of sets that ran way too hot in my Vox, and a few that were too hot in my Orange AD30. It does happen, so although it’s uncommon, IMO it’s prudent to understand that you’re dealing with a range, and at least doing a visual check to make sure they’re not red plating. I prefer to measure the bias. But not everyone has the tools or experience with that.
Hope that helps.
Amps
Vox AC4TV
Guitars
Pedals
Vox AC4TV
Guitars
Pedals
Users browsing this forum: No registered users and 315 guests
