Brent Hinds Terror amp in GW magazine
From TGP. I'll link to the pics in case some dont want any spoilers...
https://i.imgur.com/FWxDain.jpg
https://i.imgur.com/IjoyxUI.jpg
Re: Brent Hinds Terror amp in GW magazine
Looks to be a Rocker
Rocker 32 in a metal Terror cage.
It's so ugly! Hahaha.
I hope it sounds a lot more like the R30 and not the R32...If its just the R32 with his name on it in Terror size, I'll pass. The R32 is one of my least favorite Orange amps.
Did you try it through a different cab? I wasn't impressed with the 210s.
So what's its specs?
30 or 15 watts? , It looks to have 2 channels as far as I can tell from the photos and a 1/2 power switch, effects loop?, Gain stages?
It'd be interesting if it turns out to be more or less a Rocker 30 with a half power switch and an FX Loop.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Its not so much the 10s as it is the EL84s sound nothing like the 6CA7s and the Demeter transformer in my UK made R30 is far superior to the random transformer in the Chinese made R32. Check out 7:02 in this clip with the 335. The R30 sounds night and day better than the R32. That video is done direct, not using the speakers. R30 still sounds worlds better.
https://www.youtube.com/watch?v=BJg7Rs9IwDw
Thejay, a forum member here, did a comparison between his R30 and R32 through V30 speakers. Pretty much near identical.Dexter211275 wrote: ↑Mon Jan 22, 2018 6:20 amI hope it sounds a lot more like the R30 and not the R32...If its just the R32 with his name on it in Terror size, I'll pass. The R32 is one of my least favorite Orange amps.
What you probably didn't like with the R32 is the speakers.
See the link I posted above. They dont sound alike at all IMO. The R30 destroys it. It sounds way bigger, beefier and much less compressed. The R32 sounds thin, nasally and compressed.Les Paul Lover wrote: ↑Mon Jan 22, 2018 7:27 amThejay, a forum member here, did a comparison between his R30 and R32 through V30 speakers. Pretty much near identical.Dexter211275 wrote: ↑Mon Jan 22, 2018 6:20 amI hope it sounds a lot more like the R30 and not the R32...If its just the R32 with his name on it in Terror size, I'll pass. The R32 is one of my least favorite Orange amps.
Again, what you hear there is the difference between the 10" VOTW and the 12" V30.Dexter211275 wrote: ↑Mon Jan 22, 2018 7:25 amIts not so much the 10s as it is the EL84s sound nothing like the 6CA7s and the Demeter transformer in my UK made R30 is far superior to the random transformer in the Chinese made R32. Check out 7:02 in this clip with the 335. The R30 sounds night and day better than the R32.
Dexter211275 wrote: ↑Mon Jan 22, 2018 7:29 amSee the link I posted above. They dont sound alike at all IMO. The R30 destroys it.Les Paul Lover wrote: ↑Mon Jan 22, 2018 7:27 amThejay, a forum member here, did a comparison between his R30 and R32 through V30 speakers. Pretty much near identical.Dexter211275 wrote: ↑Mon Jan 22, 2018 6:20 amI hope it sounds a lot more like the R30 and not the R32...If its just the R32 with his name on it in Terror size, I'll pass. The R32 is one of my least favorite Orange amps.
That isn't the comparison he made using the same V30 cabs. He did make another one. Try and look up through his reviews, you should find it.
No, I know what the difference between 10s and 12s sound like. Im hearing the much bigger and beefier EL34s put out a way better and thicker tone vs the smaller EL84s. Not to mention the Demeter transformer in the R30 crushes the generic transformers used in the Chinese made Oranges. That makes a far bigger difference than 10s vs 12s.Les Paul Lover wrote: ↑Mon Jan 22, 2018 7:30 amAgain, what you hear there is the difference between the 10" VOTW and the 12" V30.Dexter211275 wrote: ↑Mon Jan 22, 2018 7:25 amIts not so much the 10s as it is the EL84s sound nothing like the 6CA7s and the Demeter transformer in my UK made R30 is far superior to the random transformer in the Chinese made R32. Check out 7:02 in this clip with the 335. The R30 sounds night and day better than the R32.
https://youtu.be/3ij3Gc5PXSs
That should be the R30/R32 comparison through V30.
Tell me how much of what you thought is down to valves & transformers or speakers after giving it a listen.
Users browsing this forum: No registered users and 249 guests
