Hello all! This is my first post on this forum!
I wanted to get some opinions:
I have an orange OR15 (15 watts) and I'm running it through an Orange 412. I'd like to get a 212 as well. I can run both the 412 (16ohms) and the 212 (16ohms) at the same time out of the two 8ohm outputs on the back of the amp.
Has anyone else done this? Would running my 412 and an additional 212 out of the OR15 be ok? I don't want to do anything that will harm the amp.
Thanks!
Orange OR15 with 2 cabs
Re: Orange OR15 with 2 cabs
That's perfectly safe for your amp.
Even a 1 watt amp can drive two 412's safely. (Although each speaker will get so little power that it might not sound great.) A 15 watt amp can easily drive a 412+212.
Excellent idea!! I only hope you can turn it up!
Users browsing this forum: Google [Bot] and 398 guests
