I own two OBC 810 cabs. Will i be able to chain two AD200 (connected to one cab each)? Or will i need other amps, or "worst case" - a two-channel power amp with some kind of pre-amp.
I need to blow out some windows
2 x OBC810 ----》》 2 x AD200??
Re: 2 x OBC810 ----》》 2 x AD200??
If you run a stereo or ABY pedal you can run into both amps at once, connected to one cab each.
There is a Slave Out on the AD200 however no Power Amp IN so if you wanted to use one as the primary and the other as a slave you may be better off with a single AD200 and a 200 watt Tube Poweramp to match it. Something like the Matamp Green Slave Unit:
http://www.greenamps.com/sleep/green-20 ... -unit.html
Otherwise a solid state power amp would do fine as well. As the owner of a single OBC810 and AD200 I think you are crazy... awesome, but crazy
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Windows are evil. Let's blow them all!!!!
Before you go nuts, try just running the head through both cabs. I don't think there's ever going to be a need for a second amp except for show and as a backup.
I dont think thats possible..Before you go nuts, try just running the head through both cabs. I don't think there's ever going to be a need for a second amp except for show and as a backup.
Speaker output on the AD200 is either 1 x 4ohm, 1 x 8ohm, or 2 x 8ohm.
OBC810 is 4ohm.
Im already nuts
I found the answer - use an Amp Detonator pedal.
Makes it possible to switch between amps or run both together.
ROCK ON!!!
ROCK ON!!!
You could also get a series box and run both cabs with one head as this will give you an 8ohm load.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Oh - sorry. In my head I thought the cab was 8 ohms....gasserx wrote: ↑Thu Dec 21, 2017 5:14 amI dont think thats possible..Before you go nuts, try just running the head through both cabs. I don't think there's ever going to be a need for a second amp except for show and as a backup.
OBC810 is 4ohm.
Im already nuts
Users browsing this forum: No registered users and 374 guests
