Noob
Noob
Hello all, new to this forum - just thought I'd introduce myself. I am still learning to play guitar (aren't we all!). I have some pretty cool gear (Gibson Le Pauls, Fender Stratocasters, Vintage Guild Archtops, Marshall 2245 amp, Orange Crush 35). I just ordered myself an early Christmas gift - a Orange Tiny Terror head. I heard they can get "fizzy", so also ordered the British Glory mod kit. I'll post pix and updates as the story progresses. I have a 1x12" Celestion cabinet to play around with, but also have an older Celestion-loaded Marshall 1936 2x12" to hook up to this little guy when it arrives. I am looking forward to learning/sharing with you guys.
Re: Noob
Very cool! Welcome aboard!
Re: Noob
Hi welcome to the forum.
The tiny terror is a great sounding head through a good cab, does it get fizzy ? Not in my view ....have a open mind and dont necessarily believe what you hear on forums without experiencing it yourself!!
enjoy!!
enjoy!!
Re: Noob
When I had to downsize into an apartment, I found my Tiny Terror got fizzy with high gain and the master turned way way down.
The master works very well -- it doesn't have to be super loud to avoid fizziness. But trying to keep it down to TV volumes is asking a lot from any tube amp.
Re: Noob
I think the British Glory mod is decent, less overall gain available, but I never use much anyways. It makes it a bit broader finding a crunch sound. Inthink a lot of the “fizzyness” comes from the phase inverter and this mod addresses that.
Re: Noob
Got the amp yesterday, plugged in for a short time into the 1x12" Celestion. Sounds good, but I was surprisingly underwhelmed with the difference between the 15 and 7 watt settings on the power output. I guess this is typical for these, so I'm going to play it for a while with different cab/spkr combinations before adding the British Glory mod to it. Looks like snow here in Michigan this weekend, so good time to stay inside and play!
Thanks for the warm welcome and tips.
Re: Noob
Half-power switches are widely misunderstood. It takes 10x the power to double the volume (or to cut the volume in half, you need 1/10th the power).
So in the 15 watt mode, 1.5 watts is half as loud as full volume.
Speaker efficiency/sensitivity is measured with 1 watt input. That's measured at 3 feet, but room gain in a normal sized room means that the volume doesn't drop off much as you move farther from the speaker.
You don't specify which Celestions you have, but one watt will give you 93~100dB.
The half-power switch lets you get power tube breakup at a slightly lower volume, but it doesn't make the amp a lot quieter.
It also changes the tone a bit. A little less lively, less dynamic.
It's not enough to make it apartment friendly when cranked, that's for sure.
Users browsing this forum: No registered users and 80 guests
