Hello guys,
I have had a dark terror for around 2 months now with no issues, in fact it has worked very well up to this date. I am not quite sure where I went wrong but I happened to change it to standby mode while sound was coming through and when I turned the amp back on it does not play any sound anymore. I might have done something else too but I can't remember... There is still a hum from the amp, and the power light is on so I assume it is still getting power and the tubes are glowing (maybe a little faster warm up than usual but not sure at all). Anyway it stopped working all of a sudden and I hope I didn't ruin my amp!
Please help!
Dark Terror Suddenly Stopped Working
Re: Dark Terror Suddenly Stopped Working
Check the HT fuse. If its OK it nay be a tube problem. If the fuse is bad, it also may be a tube problem.
In any case, jondog pointed you to the only 2 things a user can change themselves - fuse and valves.
If it's something else, there's nothing you can do - it's tech time.
Glowing tubes only indicate that the heaters are working.
Unless your house had a power surge, the fuse is probably blown from a bad tube. Tubes start to wear out as soon as they're put in and turned on...
I would replace the fuse and see if that's it. If it blows again, get new tubes - don't replace it more than once.
I have a new Dark Terror, not much older than yours. I do what its manual suggests to prolong tube life and let them warm up for at least the recommended 4 minutes....usually a bit longer. Before I switch to standby at the end of a session, I turn my guitar volumes all the way down. So far, so good, but in any case, if I experienced your problem, I'd seek out a tech. I have an Orange dealer in my area who I would check with.
adkguy07
adkguy07
The best thing you can do, is turn the volume on the amp all the way down, and turn the amp on without using the stand-by and let it warm up. I don't do this, I usually give it a minute, or turn it on and go get a drink or have a piss.adkguy07 wrote: ↑Sat Nov 18, 2017 5:05 pmI have a new Dark Terror, not much older than yours. I do what its manual suggests to prolong tube life and let them warm up for at least the recommended 4 minutes....usually a bit longer. Before I switch to standby at the end of a session, I turn my guitar volumes all the way down. So far, so good, but in any case, if I experienced your problem, I'd seek out a tech. I have an Orange dealer in my area who I would check with.
adkguy07
You've had it for 2 months. If you bought it new from an authorized dealer it's under warranty. Tubes warranted for 90 days, the rest of it for 1 year (extendable to 2 years if you register it on Orange's website).
(Assuming you're in the USA; warranty coverage may differ in other countries.)
Flipping the standby switch while playing shouldn't have damaged anything.
(Flipping standby or power switch on off on off on off a bunch of times quickly can be hard on the transformers and capacitors, but flipping the switch while playing and then flipping it again a few moments later shouldn't be catastrophic.)
Users browsing this forum: Google [Bot] and 356 guests
