Does anyone know if the Celestion Alnico Gold speaker will fit into a TH30 combo? The reason I ask is that the bell on the Alnico speakers is bigger/longer than the other Celestion speakers resulting in the tubes sometimes rubbing/hitting the speaker bell in some amp combos (Fender).
Celestion alnico speakers are a bit pricey and also non-returnable so before actually buying one and then discovering that it won't fit I thought I would ask here if anyone has tried it.
Thanks.
TH30 Combo and Celestion Gold Question
Admit nothing, Deny everything, Make counter accusations.
Re: TH30 Combo and Celestion Gold Question
It’s depth is 6.5”, if thats helps. Measure it out.
I just eyeballed mine and there's no way you're going to be close to the tubes. It looks to me like there's about 3 or 4 inches to spare to the back of the cabinet, so you should be just fine.
Thanks. I believe you're correct. There appears to be ample space for the larger speaker bell.
Users browsing this forum: No registered users and 198 guests
