how do i get the best chime sound on an orange amp?
how do i get the best chime sound on an orange amp for chord's?
Re: how do i get the best chime sound on an orange amp?
Hi,
What is exactly the question? Clean channel, dirty channel ? What kind of amp?
i got a orange crush 35rt amp
experiment radical tone settings. Treble and bass up middle down. etc. You need to get rid of the "fat" in the sound
Tighten the bass up
I was goona say the best way would be to sell it and buy a vox or fender hahah.
Perhaps get an EQ pedal to help bring out those "chimey" frequencies?
i was wondering what treble mids and bass i should try on my amp, but i also have a fat 50's neck pickup on my fender starcaster which looks like a fender strat, and which pickup should i use, the neck pickup, the middle pickup, the bridge pickup and 2 other pickups
Have you tried just moving them around until you are happy with the sound? For high chime I would say max the treble, lower the bass, and adjust mids to taste. It's also possible that amp can not produce the sound you are after. I'll tell you from personal experience that not every amp was designed to cover every tone.
i tried the amp settings treble 5 mids 4 bass 5 guitar volume maxed tone maxed. is that good for a chime sound?
If it sounds chimey to you, yes. We can't hear it through the interwebs....raichu4evuhs wrote: ↑Sun Sep 17, 2017 1:00 ami tried the amp settings treble 5 mids 4 bass 5 guitar volume maxed tone maxed. is that good for a chime sound?
I don't know about the tone stack in your Crush 35RT, but my own Micro Dark (a hybrid amp) and Dark Terror have that "chime" factor going on. My description of their "chime" is almost akin to the tone a harpsichord (lots of overtones) but with a bit more sustain to it and bell-like ring.
As a post above mentioned, take then"fatness" out your Crush's tone. Minimize the bass, boost highs substantially, and season with the mids control to get it bright. In both of my Oranges, I run the amp's volume and gain knobs about equal to each other. My MD's vol. and gain knobs are between 10 and 11'o'clock. The DT, at 9 and 10 o'clock, or so. Switch you the bridge pickup with guitar volume and tone full on. Playing the strings closer to the bridge brings the chime out, if it's present in that particular Orange model. BTW, I'm using a Les Paul.
adkguy07
adkguy07
Personally, I feel that Orange amps have the best "chime" or "edge of breakup" sound out of the many amps I have tried. You have to run the gain quite low. Just enough to where you're barely getting some distortion if you play hard and get a clean sound when you play soft. On my Dual Terror, I have the Master set around 11 oclock and the Gain set around 10 oclock. I boost with a Klon KTR for more overdrive. Works perfectly!
My band The Start Up
Spotify
Spotify
Users browsing this forum: No registered users and 143 guests
