I have a PPC212, so has anyone rewired a 212 cab (with 2 jacks) to have switching between stereo, single speaker or double mono (using a stereo jack) like described here: http://www.jumbosunshade.com/misc_docs/swd03.htm
Sorry if this next question seems silly: regarding the wiring demonstrated on jumbosunshade.com, is there an issue with the ground as my jack plate is metal? Does the mono jack (or both jacks) need to be isolated from each other or from the jack plate? Like using a plastic jack’s.
Thanks,
Craig
Stereo Switching PPC212 and Grounding
Re: Stereo Switching PPC212 and Grounding
Hi Craig-
Welcome to the forum!
That is a question I had never thought of before... but makes total sense. I never particularly cared for the output jacks that had a plastic base but now I can see why you would use something like that in order to isolate the ground. Otherwise, like you said, using a plastic jack plate would do the job. I think you have a valid point and I'd like to hear a couple of others weigh in that are more electronically savvy than me...
The jacks Orange use are isolated from the plate.
So you are just wiring up the stock plate to be stereo?
I bought a stereo port city cab a while back. It came with a switch to go from mono to stereo. Looks like they have a new version out. Perhaps just swap the plate with something like this? Tons of companies make them.
http://www.portcityamps.com/accessories ... -jackplate
Users browsing this forum: No registered users and 179 guests
