using a 2x12 combo with different head.
I have a cr120 combo amp. I am thinking about getting a rockerverb 100 mkIII. I was wandering if it would be ok to use the combo amp as just a 2x12 cab and plug the rockerverb into it? I would disconnect the cr120 head of course.
Re: using a 2x12 combo with different head.
Just double check the impedance of the speakers so you can plug into the correct output on the amp.
thank you. its set up with two 8 ohm speakers together to make 16 ohms.
The biggest issue when anyone tries to do this is, is the cord to the speakers long enough to reach an external head?
You would have to be careful with volume. The RV puts out way more than 100 watts at higher volume. As long as you aren't cranking it you should be fine.
You just need a female to female 1/4 adapter and a speaker cable.
Alternatively, I made a "junction box" that I have secured in each of my combos. It's basically a plastic box with 2 jacks on it. I plug the speaker lead into one, and a speaker cable (from a head) into the other. I like that it's cleaner and ensures the wires don't contact the speakers.
I keep an EH 44 magnum in my cable box as a backup amp. If my AD30 goes down, I use the 44 magnum and junction box to make the combo into a head/cab backup rig.
Oh yeah wattage switching! Forgot ha!
Users browsing this forum: No registered users and 241 guests
