Hi Guys,
I am thinking of picking up Micro Terror. Quick question that might be obvious to some but I am unsure about..
Let's say I use this amp WITHOUT a cab. Only using output via headphone jack? Is this even possible?
Thanks for your time.
quick question
Re: quick question
Yep, no problem
Re: quick question
Thanks so much for your response.
I was unsure if the Micro Terror REQUIRED a cab since there is a tube in the amp.
Again, this may seem painfully obvious to some but I had no clue, thanks again for your help.
Re: quick question
The MT is a solid state amp though it has one 12AX7 tube in the preamp cirquit. Since the power cirquit is SS it lacks output transformer which means it doesn't need a cab load.
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
Re: quick question
Thanks for the explanation : )
Users browsing this forum: No registered users and 387 guests
