Boosting the dirty channel?
Hello guys!
I have a TH30 and I really love it. Clean channel is wonderful as well as the crunch distortion on the dirty one.
Now I'd like to find a way to obtain a third sound, a lead for solos, without using OD or distortion pedals (they make one of the warmest amps brand sounding "cold", in my personal opinion) or guitar's volume knob. At first I thought about MXR micro amp on the clean channel to get a crunch sound, using and setting the dirty channel for solos. Or, in alternative, placing the pedal in the FX loop, directly boosting the dirty channel's volume, as in the last part of this video (from 7.35): https://youtu.be/j6kxXWW7O8w
If the second one worked I would definitely choose that solution, but I honestly can't hear a big volume boost. At least not enough for a solo. Any other solution?
Thank you!
Thank you!
Re: Boosting the dirty channel?
There is a nice but very expansive solution...
The Bax Bangeetar!
Can do subltle changes in my TH30 tone, or work like a 3rd Channel.
And for me it boosts very nice too.
All depending where I place it (front or loop).
IMHO they should sell the TH30 in a bundle pack with this pedal.
The only negative thing is again THE HUGE PRICE.
But I see it as one of the best investment you can make.
The Bax Bangeetar!
Without using pedals or the volume knob, there's not much you can do unless you can pick very very lightly and make it sound good, which is impractical. Also depends what you're trying to achieve, more gain, more volume, different tone/EQ, combination of, etc...Van Gogh wrote: Now I'd like to find a way to obtain a third sound, a lead for solos, without using OD or distortion pedals (they make one of the warmest amps brand sounding "cold", in my personal opinion) or guitar's volume knob.
How about trying do get a third tone using an eq pedal. I have a JoYo Fish n' Chips eq pedal. It could be used to reshape the clean tone or the gain tone and set the pedal volume to higher than parity and see what you
can find.
adkguy07
can find.
adkguy07
I also play a TH30 in my smaller rig. The thing is a beast but I have encountered exactly what you are describing. What I have found works best is cheating a little. I use my old 10 band and leave the eq flat but pull back the volume slider so I cut some volume from my amp. Then I adjust the volume on the amp to match up with everyone else in the band and when I do a solo, I kick off the 10 band and let the amp do its thing.
I would assume you could use other pedals than just a 10 band. I also have the strymon ob1 and I am tempted to try it with that but haven't gotten around to it.
Rockerverb 100 MKIII
Rockerverb 50 MKIII combo
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson explorer custom
gibson es355
gibson es359
gibson sg custom
gibson les paul custom
gibson les paul standard
gibson les paul studio
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
I think that you'll get problems on the clean channel. Boosting will give you more volume but no crunch sound. Why not choosing a mild and warm od pedal?
For example a Hotone Blues works fine with clean and crunchy channels.
Amps:
no more Orange Amps
Captain Amp Tweed Super 2x10
Blackstar Fly 3
Guitars:
Diego HSS strat
Electra Omega Prime Ceruse
no more Orange Amps
Blackstar Fly 3
Guitars:
Diego HSS strat
Boosting the clean can breakup into crunch.skerwo wrote:I think that you'll get problems on the clean channel. Boosting will give you more volume but no crunch sound. Why not choosing a mild and warm od pedal?
I'm not a th30 owner but from the Orange amps I've owned how much boost you get from the dirty channel will depend on a) how loud your playing and b) how much preamp gain your using. The lower the preamp gain the more volume boost you'll ge
Experimentation is the key , ld try a boost pedal going into the front to boost the dirty channel or set up an overdrive pedal on the clean channel to provide solo volume.
Also I'd set your preamp gain for as little as you can get away with then your more likely to get a volume boost.
Using a boost through the effects loop never worked for me while there was plenty volume the sound was much cleaner.
Enjoy!l
Enjoy!l
I'm gonna suggest putting a MXR 10 band eq in your fx loop, this pedal has a gain and volume slider so you can boost both to get a good lead tone.
100% transparent.
When I owned a TH30 I boosted it with an EQ-pedal in front of the amp. It had a slider for volume that I pushed quite hard and I put the rest of the EQ as "pig nose" with the the mids really boosted. It worked really well for me. At some point I sold the amp as well as that pedal and nowadays I have an EHX East River Drive as a boost/overdrive for my Rockverb MK 1.
/J
/J
Orange RV50 MK I Head
Orange PPC412
Orange PPC112 x2
Orange Micro Terror
Ibanez TSA15H
2x Gibson SG Standard
Peter Naglitsch Custom
Fender Tele ´72 Roadworn
Fender Tele FSR Custom
Squier Tele Classic Vibe
Jackson ATX
Jackson TH-2
Hagström Viking
Pedals...
Orange PPC412
Orange PPC112 x2
Orange Micro Terror
Ibanez TSA15H
Jackson ATX
Jackson TH-2
Hagström Viking
Pedals...
I use an Archer and a Wampler Euphoria going in the front of the amp. Works on the clean or dirty channel and will give you either a clean boost or some dirt if you wish. Both pedals will get very loud if you don't have the amp at full blast already. They don't sound cold to my ears.
i know you don't wish to use an OD pedal, but one in the loop with some little gain/dirt would give you exactly what you are looking for.. add volume for lead, and the eq on OD pedals (mostly a 1kHz hump) is perfect for cutting through the mix.
-Ian-
2014 G&L Fallout
2014 G&L Fallout
TC Spark boost (full sized, four knob version) in the effects loop will do exactly what you want as a lead boost on the dirty channel. Its very transparent and has some nice tone shaping controls, relatively cheap too. It works wonders for my Dual Dark 50.
Orange Dual Dark 50
Rocker 30 head
Framus 4x12 V30s
Fender Pro Jr.
LP Classic 2006
LP Standard 1993
SG Standard 1992
Rocker 30 head
Framus 4x12 V30s
Fender Pro Jr.
LP Classic 2006
LP Standard 1993
SG Standard 1992
After reading my last post I remembered this:
https://www.youtube.com/watch?v=eh6Ljr0m3Ok" onclick="window.open(this.href);return false;
Not that expansive and I bet your TH30's sound could benefit from one those.
I'm still tempted to buy the Two Stroke....
Users browsing this forum: No registered users and 82 guests
