Amp simulators
Re: Amp simulators
Amplitube. It's pretty much the only option for bedroom levels and being able to get some "useable" gain. Mini-heads like the microterror are fun but if your used to playing high-gain stuff the volume tends to increase substantially
Re: Amp simulators
I'm running headphones. Can't wake up the toddler.... or the neighbors, or the wife... So yes, Amplitube is not a bad idea in the least bit...MikeD wrote:Amplitube. It's pretty much the only option for bedroom levels and being able to get some "useable" gain. Mini-heads like the microterror are fun but if your used to playing high-gain stuff the volume tends to increase substantially
-LK
Re: Amp simulators
Yeah than I think youve found what your looking for. I was quite impressed by the feeling you get from it, theyve done a pretty good job when it comes to string sensitivity and break-up and the sounds "remind" you of the real thing....well sort of. Some of the oranges are better than others and the slash marshalls are really funWired wrote:I'm running headphones. Can't wake up the toddler.... or the neighbors, or the wife... So yes, Amplitube is not a bad idea in the least bit...MikeD wrote:Amplitube. It's pretty much the only option for bedroom levels and being able to get some "useable" gain. Mini-heads like the microterror are fun but if your used to playing high-gain stuff the volume tends to increase substantially
Re: Amp simulators
If your using iPad or iPhone it's also worth checking out Jam up and Bias alongside Amplitube.
Both have good and not so good models.
If you buy one of the line 6 Sonic Port interfaces you get Mobile Pod for free and can still use the others.
Re: Amp simulators
Similiar to what a few others have said. I have been more than impressed with using the "Apogee Jam" ~$99 with plane old Garageband on my iPhone and iPad. The "sunshine" amp is pretty good IMO. Im sure Bias or Amplitude have better sims but GB isn't half bad at all and its free
https://soundcloud.com/sixtenconnector/" onclick="window.open(this.href);return false; ... nnector-ep
Users browsing this forum: Google [Bot] and 266 guests
