Dual Dark 50...
Re: Dual Dark 50...
How's the effects loop on the Dual Dark, good for delays? I have a Ceriatone Silver Jub clone with a tube buffered loop and my Flashback delay sounds like butt in the loop. My Fulltone Fatboost works well for a boost there, but I was really disappointed with the delay there. Tried a Boss DD-3 as well, no dice.
Also, is it possible to get close to R30 dirty tones with this amp? The youtube vid by Fluff made this thing sound kinda fizzy and undefined to me, but I really like the features on this amp.
Orange Dual Dark 50
Rocker 30 head
Framus 4x12 V30s
Fender Pro Jr.
LP Classic 2006
LP Standard 1993
SG Standard 1992
Rocker 30 head
Framus 4x12 V30s
Fender Pro Jr.
LP Classic 2006
LP Standard 1993
SG Standard 1992
Re: Dual Dark 50...
Here's a few rough mic tests I've done with placement and EQ changes:
Audix I5
https://soundcloud.com/john-greenhill/a ... al-dark-50" onclick="window.open(this.href);return false;
Se Z3300a
(friend playing whist I move the mic and adjust amp settings)
https://soundcloud.com/john-greenhill/o ... test-jason" onclick="window.open(this.href);return false;
SE Z3300a
https://soundcloud.com/john-greenhill/d ... ty/s-dF3Yf" onclick="window.open(this.href);return false;
Audix I5
Se Z3300a
SE Z3300a
Dual Dark 50
PPC-212
Hardwired Tiny Terror
http://www.facebook.com/iLLUSTR8ORS" onclick="window.open(this.href);return false;
PPC-212
Re: Dual Dark 50...
you guys know you can do a private youtube video and just post the link here right........?
am fascinated that there are two cleans available.. is this also at volume?...
-Ian-
2014 G&L Fallout
2014 G&L Fallout
Re: Dual Dark 50...
Yes, both channel volumes right up with the gain down lower, and on 50 or 25 watts...basically clean as a whistle if you like, but I always prefer a bit of edge.Mystic38 wrote:
I am fascinated that there are two cleans available.. is this also at volume?...
Re: Dual Dark 50...
BlackWolf uses Dual Dark? I know what amp i'm getting for my birthday
Play till you slay
Amps:
Orange Dual Dark with PPC 212
Line 6 spider
Effects:
DD-3
SD-1
NS-2
Spark Booster
Crybaby Wah
Guitars:
Epiphone Sheraton
HSS American Deluxe Fender Strat Shawbucker
Fender standard Telecaster
Amps:
Line 6 spider
Effects:
DD-3
SD-1
NS-2
Spark Booster
Crybaby Wah
Guitars:
Epiphone Sheraton
Re: Dual Dark 50...
I don't want to play a Dual Dark, I know the GAS will be unstoppable if I do!
Congrats!
Congrats!
Re: Dual Dark 50...
I'm not sure about the R30 bit, having never played one. I can tell you that it is not by any means undefined. My carbon Copy delay sound brilliant through the loop. Just sounds like a great analog delay to my ears.apocalypsedude wrote:How's the effects loop on the Dual Dark, good for delays? I have a Ceriatone Silver Jub clone with a tube buffered loop and my Flashback delay sounds like butt in the loop. My Fulltone Fatboost works well for a boost there, but I was really disappointed with the delay there. Tried a Boss DD-3 as well, no dice.
Re: Dual Dark 50...
Orange Dual Dark 50 - Les Paul Test: http://youtu.be/TL-kgPGjagM" onclick="window.open(this.href);return false;
I thought this sounded pretty darn good
Edit: this is double tracked....read it in the comments
Re: Dual Dark 50...
Yep Really does sound good.ironlung40 wrote:Orange Dual Dark 50 - Les Paul Test: http://youtu.be/TL-kgPGjagM" onclick="window.open(this.href);return false;
Re: Dual Dark 50...
I believe that's another demo from John.Ronnie Robinson wrote:Yep Really does sound good.ironlung40 wrote:Orange Dual Dark 50 - Les Paul Test: http://youtu.be/TL-kgPGjagM" onclick="window.open(this.href);return false;
Does sound really good. Too tight for me, but that's a beast of an amp for classic rock, hard rock and more.
Re: Dual Dark 50...
Yes, tight does describe it very accurately. Great amp and very flexible, but another amp is in order to cover all bases. I might have to be rid of the YJM in favor of a RVMKIII (hint Hint)...
Re: Dual Dark 50...
+1Wendigo wrote:(hint Hint)...
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
Re: Dual Dark 50...
Bear in mind this was recorded at bedroom levels. Cranking the volumes to 7 or 8 with the band brings in some sag and compression to the attack, as-well as getting the speaker moving properly.Les Paul Lover wrote:I believe that's another demo from John.Ronnie Robinson wrote:Yep Really does sound good.ironlung40 wrote:Orange Dual Dark 50 - Les Paul Test: http://youtu.be/TL-kgPGjagM" onclick="window.open(this.href);return false;
Dual Dark 50
PPC-212
PPC-212
Users browsing this forum: Google [Bot] and 401 guests
