OT: Not getting reading from neck p'up!
BrianFantana
Post by BrianFantana » Mon Sep 01, 2014 12:11 am
So, being the twiddler I am - I've been messing with pickup changes. When I went to put my SD '59 back in the neck of my Les Paul, I noticed that it sounded like a single coil...I took the joker TOTALLY apart to check the connections and everything seemed to be wired properly, but NO CONTINUITY between certain points.
What in the world could I have done?
Any suggestions / (non-smart arse) advice? 8)
OU818
Re: OT: Not getting reading from neck p'up!
Post by OU818 » Mon Sep 01, 2014 12:18 am
I suggest posting photos.
Orange Gear:
AD200B MkIII
Terror Bass MkII
OBC810
Non-Orange:
Barefaced Super Twin
Basses:
Sandberg Electra VS4
Polaris Manta V Custom
Hubaxe
Orange Expert
Post by Hubaxe » Mon Sep 01, 2014 10:00 am
On SD bobbins are:
bobbin 1 Black-White
bobbin 2 Red-Green
Have you tested the bobbins individually? How many ohm do you read ?
The value for each bobbin should be similar. If the ohmmeter display 1, the bobbin is cut.
If both bobbin are ok, connect the white with the red, and mesure between Black and Green.
If all mesurement are ok, try to connect the jack directly on the black (hot) and green (ground).
Users browsing this forum: Bing [Bot] and 44 guests
