Finally, a re-amping device with a reactive load, twin channels and a loop. I read where the owner stated the load response is based on the Bad Cat custom Celestion speaker. Does anyone know how those sound?
I think I'm gonna have to at least check one of these out. The post-amp fx loop should make delay and reverb sound a whole lot better through the OR120.
Bad Cat Unleash
Re: Bad Cat Unleash
You'd have to be careful, it's not meant for amps highr than 100wattsyossarian83 wrote:Finally, a re-amping device with a reactive load, twin channels and a loop. I read where the owner stated the load response is based on the Bad Cat custom Celestion speaker. Does anyone know how those sound?
Re: Bad Cat Unleash
I don't think an OR120 puts out significantly more wattage than an old 100 watt Marshall... they're both 4xEL34's and run similar voltages. Or course, I'm assuming that when they say "100 watt amp" they're talking a tube amp so it's understood that they're load is rated for more than 100 total watts.
Re: Bad Cat Unleash
I have been wanting to check one of these out for a while to use with my 6G2 combo amp.
May have to grab one after I get back from Europe in Jan.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Re: Bad Cat Unleash
I wouldn't assume that!!!yossarian83 wrote:I don't think an OR120 puts out significantly more wattage than an old 100 watt Marshall... they're both 4xEL34's and run similar voltages. Or course, I'm assuming that when they say "100 watt amp" they're talking a tube amp so it's understood that they're load is rated for more than 100 total watts.
Unfortunately for you in the PDF manual I'm seeing
and'max 100W'
The fully distorted outputs of old Marshalls / Hiwatts and (especially!) Oranges are so much higher than that that I think rapid failure is practically guaranteed. All of these amps based right with good valves can put out up to around 140W 'clean'. The maximum distorted output of the Orange may well be the highest of the lot though. That was the indication I got from my old tech John Phillips when we were discussing a small Hiwatt fuse blowing problem I had with my Hotplate attenuator while back.'attenuating more than 100W into the Unleash can cause the Unleash to fail.'
The THD Hotplate is one of the few which'll handle an OR120 full blast near full attenuation and even then he thought it was probably pretty marginal. They are rated for around 170 - 180W...
Most attenuators (unlike Celestion speakers) sadly aren't rated for the amp ratings but for the actual wattage they will handle - very different numbers.
Users browsing this forum: No registered users and 381 guests
