Does your FS-1 light up?
Mine (brand new) seems to switch fine but the indicator light doesn't light up.
Re: Does your FS-1 light up?
Yes. And so should yours. Dead bulb or loose wire to the light? Easy fix I'd think but brand new so best just send it back.
Gibson Les Paul standard
Fender strat
CV tele
Epiphone Sheraton
Charvel pro Mod type 2
Faith and eko acoustics
Orange dual terror
Fender Blues Jr
Ppc112 cab
Proc212ob cab
Peavey deuce
Not enough pedals!
Fender strat
CV tele
Epiphone Sheraton
Orange dual terror
Fender Blues Jr
Ppc112 cab
Proc212ob cab
Peavey deuce
Not enough pedals!
For what amp?
Bulb is fine; I just ran 9V directly to it. Reheated the solder joints, still nothing. This just picks up 'phantom power' from a regular guitar cord, correct? Any footswitch I've had previously had it's own cord.
CR35LDX amp. I unplugged from the amp and touched the cord plug to the 9V battery and the bulb lights on & off with the footswitch activated, so it appears the pedal is fine. Amp not sending power?
The LED is indeed powered by the amp but while this works across most of the Orange range, this is not supported by the CR35LDX (or any of the entry level Crush series). SorrySkydog wrote:CR35LDX amp... Amp not sending power?
If you want it to light up, a battery and appropriate wiring mod should get the result - there's enough room in there...
Rb
CR60C+PPC112 Mini Stack
MarkBass Micromark 801
The Provocateurs Bandcamp
No, if you can't tell if it's on, you probably don't need it, right?! Thanks everyone, at least I know it ain't broke!
Users browsing this forum: No registered users and 324 guests
