...suspected GAS issues....
I think I may have a problem......but now I can at least enjoy my rockerverb at home to after purchasing this cute little 112!!!
Re: ...suspected GAS issues....
Beauty. ......but 2 x 112s sounds even sweeter!
Careful with that 112. The RV100 manual mentioned something like 240 watt maximum output on the dirty channel. I was always worried about running it with my 212. Using those guide lines I wouldn't doubt it if the RV50 can easily get over 100 watts at higher volumes. That being said, the manual has nothing about "peak" wattage.
Have fun
Have fun
The RV in the pic us, RV50. The manual for the RV50. MkI stated peaks at .90W. The RV100 with KT88 can put out140w clean , so 240 watt peak sounds about right in that configuration.Boy_Narf wrote:Careful with that 112. The RV100 manual mentioned something like 240 watt maximum output on the dirty channel. I was always worried about running it with my 212. Using those guide lines I wouldn't doubt it if the RV50 can easily get over 100 watts at higher volumes. That being said, the manual has nothing about "peak" wattage.
Have fun
Oh, and very cute - if lethal - looking rig! I regularly practice at home with mine too, it sounds great at low volumes!!!!
Les Paul Lover wrote:Oh, and very cute - if lethal - looking rig! I regularly practice at home with mine too, it sounds great at low volumes!!!!
it so does...now would someone like to fill me in on exactly what "be careful" and all that technical mumbo jumbo means?
Ronnie Robinson wrote:Beauty. ......but 2 x 112s sounds even sweeter!
the 212 lives at the rehearsal studio...and it does sound sweet.....but not in small enviroments ...such as smaller pubs and my basement....way too frikin loud with good tones....and really awful tone with correct volume
Don't crank it up too loud and you should be fine.
As the volume/gain goes up, so does the wattage (AFAIK anyway). This is why it is typically recommended that your speakers have double the handling of your amps wattage.
Nice one!
I have the same setup at home sometimes, when I bring my RV50 home for recording or practice. We´ve actually recorded the majority of the guitar tracks on our upcoming album with that setup Sounds really nice.
/J
/J
Orange RV50 MK I Head
Orange PPC412
Orange PPC112 x2
Orange Micro Terror
Ibanez TSA15H
2x Gibson SG Standard
Peter Naglitsch Custom
Fender Tele ´72 Roadworn
Fender Tele FSR Custom
Squier Tele Classic Vibe
Jackson ATX
Jackson TH-2
Hagström Viking
Pedals...
Orange PPC412
Orange PPC112 x2
Orange Micro Terror
Ibanez TSA15H
Jackson ATX
Jackson TH-2
Hagström Viking
Pedals...
The Rockerverb 50 running two EL34's cant put out more than 50 watts. Its fine. Its no different than the 1x12 combo.
50w clean (RMS) / 90w peak.Jondog wrote:The Rockerverb 50 running two EL34's cant put out more than 50 watts. Its fine. Its no different than the 1x12 combo.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
I use my Rv50 frequently with a ppc112 and it sounds good. ..is it new?
That speaker will sound so much better after 100 hours or so use
Thats some nice marketingOU818 wrote:50w clean (RMS) / 90w peak.Jondog wrote:The Rockerverb 50 running two EL34's cant put out more than 50 watts. Its fine. Its no different than the 1x12 combo.
Well yes I know peak is bandied around as much as Class A however saying it can't put out more than 50w isn't entirely accurate. Can it pump out a sustained 90w, hell no.Jondog wrote:Thats some nice marketingOU818 wrote:50w clean (RMS) / 90w peak.Jondog wrote:The Rockerverb 50 running two EL34's cant put out more than 50 watts. Its fine. Its no different than the 1x12 combo.
Can it go above 50 watts, sure.
Did I run out of caring about my own post half way through it, you better believe it
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
yupp ....there was like one used up for sale in Sweden....and not far away from the price of a new so I took the leap. So much better than amplitube which was really sucking the balls out of my rock!!!Ronnie Robinson wrote:I use my Rv50 frequently with a ppc112 and it sounds good. ..is it new?
Users browsing this forum: Google [Bot] and 326 guests
