Dark Terror through PPC412hp-8, Am I doing something wrong?
Kenji
Post by Kenji » Thu Apr 24, 2014 8:42 pm
I'm buying a Dark Terror, I know I love the sound and I also found a PPV412HP-8 for around 550$ (good deal). Will I regret buying a high power cabinet and running a 15/7 watt Amp through it?
Thinline_slim
Re: Dark Terror through PPC412hp-8, Am I doing something wro
Post by Thinline_slim » Thu Apr 24, 2014 9:01 pm
The hp8 has Celestion G12K100 speakers, which are pretty neutral sounding to me. Not like a PA speaker but a neutral guitar speaker. The standard PPC414 cab is loaded with Vintage 30 speakers. I personally would take the G12k100s over Vintage 30s but neither are my go-to speaker. I did have a G12k100 in my PPC112 for a short time. Sounded pretty good with my Tiny Terror.
As for the power handling, I wouldn't worry about it. A Dark Terror won't be able to push any 412 hard enough to get a lot of speaker break-up so it really comes down to which speaker you'd prefer.
Jake
OrangePaul wrote:Ok gitar lead to you Jake :D
"One of the 400"
Bensnake
Post by Bensnake » Thu Apr 24, 2014 9:51 pm
Kenji wrote:I'm buying a Dark Terror, I know I love the sound and I also found a PPV412HP-8 for around 550$ (good deal). Will I regret buying a high power cabinet and running a 15/7 watt Amp through it?
It'll be fine as long as you don't wanna build a full stack. You can't connect two 8 Ohm cabs to the Dark Terror...
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
hitgar
Orange Hero
Post by hitgar » Thu Apr 24, 2014 10:15 pm
I run an OR15 through a 2X12 with a 140w rating and it sounds awesome to me. As long as it sounds good, it is good. :D
Man1ak
Orange Hero
Post by Man1ak » Fri Apr 25, 2014 4:41 am
hitgar wrote:I run an OR15 through a 2X12 with a 140w rating and it sounds awesome to me. As long as it sounds good, it is good. :D
So do I and I fully agree :) I was reading this article https://www.soundonsound.com/sos/feb12/ ... eakers.htm about speaker designs and this guy from Celestion is saying that the speakers are designed to breakup on low power. Check it out, it's really interesting.
Randy Bass
Lord of Orange
Post by Randy Bass » Fri Apr 25, 2014 1:30 pm
It's not crazy. The PPC112 actually came loaded with a G12K-100 when it was first introduced and it was intended by Orange to be the ideal cab for the Tiny Terror. If you don't need/want the speaker to color your sound as much as most Celestions do, the G12K-100 is a good option. Speaker breakup can be appealing for some styles (mainly Classic Rock), but it is not at all necessary (or desired) for newer/heavier stuff.
One warning though - the Dark Terror will sound huge and quite loud through a 4x12 cab with reasonably efficient speakers, so don't plan on this being your bedroom rig. You'll have a hard time not wanting to crank it.
Thinline_slim
Post by Thinline_slim » Fri Apr 25, 2014 2:34 pm
Randy Bass wrote:One warning though - the Dark Terror will sound huge and quite loud through a 4x12 cab with reasonably efficient speakers, so don't plan on this being your bedroom rig. You'll have a hard time not wanting to crank it.
That's the same reasoning I give my wife when I've got my OR50 cranked in the house when she's home. :D
Jake
"One of the 400"
Users browsing this forum: Google [Bot] and 10 guests
