Hi there,
Anyone here using this piece of kit?
Tell me about it. I think i want it.
Strymon Flint
Strymon Flint
Squier 15 (1988)
Mesa/Boogie F50 (2005)
Orange CR60C (2014)
Orange CR60C (2014)
Re: Strymon Flint
I dont own the flint, but I have thé Blue Sky, mobius and Timeline. Strymon are top notch pedals. Excellent transparency, switching and construction. Thé effects are as good or better sounding than anything Ive played.
Re: Strymon Flint
I've a Flint.
Bullet proof construction, great sound (well not when I'm playing through it!) but quite a large power draw if you are running it through a baord mounted battery (I had it connected to a Pedaltrain Volto - Which has since been returned faulty [avoid!]).
http://www.youtube.com/watch?v=kuOYdoG74vk" onclick="window.open(this.href);return false;
Or if you like your gear demos with a little less dry:
http://www.youtube.com/watch?v=GG4g8T8-yfk" onclick="window.open(this.href);return false;
Gear: Kurt Cobain Jaguar, Kurt Cobain Mustang, American Std Tele ('10 3burst), Gibson Les Paul Std ('97 Honeyburst), Orange OR15, Orange Tiny Terror HW, Vox Night Train NT15H, Marshall JCM-1H, PPC112 Cab & a Marshall Custom Pin-Up
Re: Strymon Flint
Never played one, but I used to own another Strymon pedal and can agree that they are top notch in quality and construction! If I had the money and necessity I'd likely have a pedal board full Strymon products.
Gibson SG Standard
Sovtek Mig 100h
TC Alter Ego
Mesa Oversized 412
Re: Strymon Flint
I think Strymon pedals require more current than a typical pedal. They aren't designed to run off batteries.CarbonToe. wrote:I've a Flint.
Re: Strymon Flint
As long at the battery pack has enough mA it shouldn't be an issue should it? They aren't designed to run off your standard alkaline but with something like the Sanyo Pedal Juice (or Volto) that will supply 1000mA at 9V for a couple of hours I don't think it would be a problem. Am I wrong?Jondog wrote: I think Strymon pedals require more current than a typical pedal. They aren't designed to run off batteries.
I have a Pedal Juice and even though I haven't tried it with with my El Cap I'd like to know before I need to try it.
As for Strymon Foef, I've been running an El Capistan for a couple of years now and I've had a Mobius for about a year now. I think they are great pedals.
Jake
Re: Strymon Flint
I was curious so I looked at the manual. Says the Volto isn't designed for these types of pedals.Thinline_slim wrote:As long at the battery pack has enough mA it shouldn't be an issue should it? They aren't designed to run off your standard alkaline but with something like the Sanyo Pedal Juice (or Volto) that will supply 1000mA at 9V for a couple of hours I don't think it would be a problem. Am I wrong?Jondog wrote: I think Strymon pedals require more current than a typical pedal. They aren't designed to run off batteries.
from manual:
Battery Life
VOLTO is a powerful 2000 mA lithium-ion battery that can power a typical five-pedal
Pedaltrain for up to 36 hours of continuous use. However, VOLTO performance varies
on a number of factors:
1) Quality of stored charge
2) Draw of your pedals
3) Type of your pedal
4) Use of your pedals
VOLTO can have amazing battery life when powering pedal varieties that use a standard
9-volt battery. Just about every analog overdrive, phase, flange, delay, compression and
tremolo pedals fall into this category. Tuners too.
Certain pedals, like high-fidelity digital delays and reverbs, draw very large amount of
power and are frequently is an “always on” mode. “Always on” can mean two things: a)
the player leaves the effect engaged all the time, or b) the pedal is drawing current
regardless of whether or not the effect is engaged. While VOLTO can power these
pedals, it is important to note that VOLTO was not designed to power these types of
effects as a primary function. VOLTO’s battery life will be diminished using the pedal
types.
Re: Strymon Flint
Since i have a s[are 250mA output on my PedalPower2+ this will not be very much of a issue.
Might as well order it then. As no shop in my region carries them.
Thanks guys!
Thanks guys!
Squier 15 (1988)
Orange CR60C (2014)
Orange CR60C (2014)
Re: Strymon Flint
Thats the other great thing about Strymon. They are not a huge company and maintain a bit of a boutique status by selling direct and they keep their prices reasonable for what you get.Foef wrote:Since i have a s[are 250mA output on my PedalPower2+ this will not be very much of a issue.
Thanks guys!
Re: Strymon Flint
It is a fantastic pedal. I owned one for a while (I have a Strymon Big Sky now) and it is one of my favorite reverb pedals. It does a very good spring emulation and the 80's mode is just killer for more "ambient" type reverbs. The tremolo is pretty nice too. I liked it a LOT more than the Blue Sky.Foef wrote:Since i have a s[are 250mA output on my PedalPower2+ this will not be very much of a issue.
Thanks guys!
Re: Strymon Flint
I'd like to clarify about the Volto.
I pre-ordered it before the specs were fully disclosed.
It did power the Flint without issues but running with another 3 pedals drained it in about 2 hours (when new).
Over time the Volto became unreliable drainining its charge from any time 1 hour to 3 hours with no change of use, and the blue battery level indicator was totally unreliable and did not refelct the time left to run. After about 3 months use it stopped charging altogether. So it's been returned and I'm waiting to hear from the site I purchased it from for a refund as I do not want a replacement.
Re: Strymon Flint
I had one for a few days. It requires 250ma. Using 5 or 6 on a pedal power 2+ or any of the high voltage outs on a pedal power 4X4 or pedal power digital works just fine.
I only liked the room verb with the mix and decay all the way up (sounds amazing like this). I liked one of the trems, but couldn't find a use for it. The trem delay on my timeline does the job just fine. I also had the tap/favorite button. The tap tempo was a little sketchy in it's operation. The button doesn't register half the time unless you really stomp it, and like others have said, it's pretty tough to get it synced up due to the initial effect drop out.
I still have the BlueSky. I'm a sucker for the shimmer effect so I couldn't live without it.
If I was going to get another trem unit, I think I would go for the empress one. It has way more features, it's a little cheaper, has a flashing tempo light , midi , a control port, and multiple waveforms/note settings.
Much better value IMO.
Re: Strymon Flint
i have an el capistan, running thru my effects loop. simply amazing in its depth and transparency. if you want wow and flutter and tape crinkle, these provide some unique effects. its always 'on' and i just forget about it and make music. my next strymon (when i can cough up another 3 bills us) will be the rotary pedal.
Users browsing this forum: Google [Bot] and 186 guests
