Orange footswitch too big... or is it?
I've been trolling around on the forum a bit over the past couple months. This is my 1st thread start. Anyway, I finally decided my footswitch was too big. So I spent a couple hours with a demel and my Orange pedal is now a Rang pedal. Thought I'd share.
Orange AD30htc
Orange Tiny Terror
Orange PPC212
Orange PPC112
Gibson LP Standard (Double Cut)
Fender American Deluxe Telecaster
Taylor T5 Custom Koa
Taylor 314ce
Little Martin
Lots of Pedals
Orange Tiny Terror
Orange PPC212
Orange PPC112
Taylor 314ce
Little Martin
Lots of Pedals
Re: Orange footswitch too big... or is it?
Neat. I wouldn't have done that.
Cool.
My first thought was, first time you step on that and it flips over you'll wish you weren't so zealous with the Dremel...
Just need some Godlyke power grip now and you're set!
TH 30
You could always paint the 'O' and 'E' on the sides...
Yeah, it is a bit big I guess. That's definitely a solution!
Jenny Craig signature model.
TH 30
Mine's a double so it doesn't seem as big by comparison.
Woodsie wrote:Mine's a double so it doesn't seem as big by comparison.
I like that big double footswitch too! I think it looks cool too. The day I build my pedal board, it will have place or pride!!!!
It's pretty solid with the Velcro that comes with the pedal train.bclaire wrote:Cool.
Orange AD30htc
Orange Tiny Terror
Orange PPC212
Orange PPC112
Taylor 314ce
Little Martin
Lots of Pedals
Orange Tiny Terror
Orange PPC212
Orange PPC112
Taylor 314ce
Little Martin
Lots of Pedals
Very interesting idea!joeminer wrote:I've been trolling around on the forum a bit over the past couple months. This is my 1st thread start. Anyway, I finally decided my footswitch was too big. So I spent a couple hours with a demel and my Orange pedal is now a Rang pedal. Thought I'd share.
I got around the Orange pedal thing using a looper...
I use a Road Rage true-bypass buffered looper ( http://www.roadrageprogear.com/ ) on my board and had one of the switches wired to control the channel switching for my Rocker30, AD30 and OR50. While unfortunately having to sacrifice a loop point on the loopper, I gained a LOT of pedal board real estate.
Works great though...but maybe not so well for an amp that requires dual switches?
Orange AD30HTC
Orange Rocker 30 Combo
Orange OR50H
Orange PPC212 x 2
Orange OR50H
Orange PPC212 x 2
Here's mine. Built it a few days ago. Has an effects loop that switches off when I switch the dirty channel on. This lets me run pedals like the Wampler Black 65 on the Natural channel and switch to the dirty channel without the pedal(s) in the signal. Works great! Fender Deluxe on one channel Orange goodness on the other and no tap dancing! Don't have it all hooked up at the moment, redoing my board.
That's pretty cool and I agree the size of the foot switch is really big compared to what the circuit is. Once I figured that out I just wired my own in a new enclosure. It's the silver square on the bottom rung of the board under the wah in the pic.
Jake
That is such a great idea!!!!!!Jondog wrote:Here's mine. Built it a few days ago. Has an effects loop that switches off when I switch the dirty channel on. This lets me run pedals like the Wampler Black 65 on the Natural channel and switch to the dirty channel without the pedal(s) in the signal. Works great! Fender Deluxe on one channel Orange goodness on the other and no tap dancing! Don't have it all hooked up at the moment, redoing my board.
So you have like 5 1/4" jack input in that one little pedal? And I assume the little LED is fed by the amp like an oridnary footswitch is?
What do you do if you need some effects for your dirty/leads part?
Yes, 5 jacks, LED is hooked to the amps circuit for power. The only effects I put in the loop are ones dedicated strictly for the Natural channel, the Black 65 in my case.Les Paul Lover wrote:That is such a great idea!!!!!!Jondog wrote:Here's mine. Built it a few days ago. Has an effects loop that switches off when I switch the dirty channel on. This lets me run pedals like the Wampler Black 65 on the Natural channel and switch to the dirty channel without the pedal(s) in the signal. Works great! Fender Deluxe on one channel Orange goodness on the other and no tap dancing! Don't have it all hooked up at the moment, redoing my board.
Users browsing this forum: No registered users and 266 guests
