I know what you're saying, but all depends what's on your board. Some pedals sound better or different with an un-buffered signal such as some fuzz pedals. I use my Strymons buffer (which I think sounds nicer than Boss) at the end of my chain. If I have a buffered pedal before my fuzz, it's in a true bypass loop. I do hear a difference if I have a buffered signal into my fuzz.irish_admiral wrote:But still shouldn't make any difference if you were to have it at the front, especially for the occasions when wireless isn't in use...
I think I need a buffer
Re: I think I need a buffer
That's a fair point. As always, give it a go in both, and see what works...
Adjusting the gain on the wireless will help too!
Just my two cents here... I currently have a lot of pedals in my board, since I am in a cover band that does a lot of different styles. I found that the Wampler Decibel + worked very well to adress that signal loss due to a lot of cables... Just run it with the gain dial at zero and keep it on all the time. It really does make a difference!
Here is a video of Brian trying one out: http://www.youtube.com/watch?v=b1JgCaMujRY" onclick="window.open(this.href);return false;
Cheers
Cheers
Marshall Vintage Modern 2266c
Reeves Custom 10HG
Orange PPC212 OB
Gibson Les Paul Traditional
Gibson Les Paul Standard
Fender Telecaster JA90
A few pedals
enricoromanielo wrote:Just my two cents here... I currently have a lot of pedals in my board, since I am in a cover band that does a lot of different styles. I found that the Wampler Decibel + worked very well to adress that signal loss due to a lot of cables... Just run it with the gain dial at zero and keep it on all the time. It really does make a difference!
Cheers
I like it
Woodsie wrote:enricoromanielo wrote:Just my two cents here... I currently have a lot of pedals in my board, since I am in a cover band that does a lot of different styles. I found that the Wampler Decibel + worked very well to adress that signal loss due to a lot of cables... Just run it with the gain dial at zero and keep it on all the time. It really does make a difference!
Cheers
I like it
Sure you´ll love it. Great pedal! It also works as a boost, you could just turn up the gain knob (although,as far as boost goes, I much prefer my Fulltone Fat Boost).
Reeves Custom 10HG
Orange PPC212 OB
A few pedals
Users browsing this forum: No registered users and 342 guests
