Narrowing down amp choice
Hey guys, I'm in the market for an Orange amp.
I'll have to make a couple of trips outside town in order to test different Orange amps, and I'd like to narrow down my choice beforehand so I know where to go and what to look for.
I want a powerful, sludgy amp with plenty gain on tap and a roaring bottom end. The kind that makes windows quake and your stomach churn.
The lightest I'll be playing is stuff like Sabbath. Heaviest is stuff like Acid Bath and Sleep.
Tone I'm really looking to nail is the likes of Kyuss, Boris and Torche.
I don't need clean tones so a clean channel is optional. I only clean up with the volume knob, so good responsiveness to dynamics is a plus
Reverb and FX Loop are also optional. I don't like running reverb before mixing and I don't need an FX Loop as the only thing I'll be running is an Eau Claire Thunder in front of the amp.
Thanks guys!
Thanks guys!
Re: Narrowing down amp choice
Not familiar with some of those bands but sounds like a thunderverb 50 could work well
Mesa boogie Stiletto ace
OR 50 40th anniversary
Orange CS50
Orange 2x12 ppc
Avatar 2x12 G12-65s
Mesa Boogie wide body 1x12
Gibson Les Paul custom 58 vos
Gibson les Paul custom 57 vos
Orange CS50
Orange 2x12 ppc
Avatar 2x12 G12-65s
or the Th100
Welcome to the forum
- Prince of Orange
Thunder or Rocker series
Joe
G(sus) saves
G(sus) saves
Rocer30
OR50
OR50
Orange Rocker30C loaded with a Creamback 65
Zilla Super Fatboy 2x12 loaded with Creamnback 65's
Gibson Flying-V - PRS Mira S2
Thunderverb
The TH100 has tons of gain on tap, but the shape knob and the lack of an EQ section, might require an EQ or fuzz pedal to get a thick sludgy distortion.
Someone wrote a review of the Thunderverb 50 or 200 somewhere here on the forum, and described is a dark sounding amp, which in my mind would fit perfectly with a sludge band.
Otherwise the Rockerverb seems the good allround choice.
Gear: Orange Rocker 30 head, Orange TH100 head, Orange PPC212OB cab, pedals galore, Fender MIJ 52 RI Tele w. BKP Blackguard Flat '52s, Fender MIA Standard Strat w. Fender CS Fat '50s, ESP LTD MH-1000 w. BKP (AlNiCo) Nailbomb/VHII.
Thunderverb 200.
-Electrical Guitar Company "Buzzo" Double-Cut, Solid Aluminum, Gold Anodized.
-Gronlund Newcomb Custom aluminum hollow-body guitar.
-Matchless Phoenix 35 w/ Matchless 4x10 Cabinet
I would say if you want density ala sleep, go with either the Thunderverb 200 or the OR100. If you want Torche like tones, get the TH 30 or Rockerverb 50/100. If you want Boris, buy one of everything Orange makes!
RV50MKII [black]
PPC212C [black]
'96 Marshall 1987x (Metropoulos Modded)
'92 Fender MIJ '72 Thinline Tele w/Flamed maple neck
'12 Fender American Deluxe Tele
'12Fender American Standard Tele
'12 Fender JA-90
'14 PRS S2 Starla
Hopeless Fender devotee
GAS Anonymous.
PPC212C [black]
'12 Fender JA-90
'14 PRS S2 Starla
GAS Anonymous.
This does all you are looking for. Shakes walls, sludgy.0000 wrote:Thunderverb 200.
So, the consensus is the following series:
Thunder/Thunderverb
Rockerverb
OR
I'll still have to make two trips, but it's certainly a break from the 4 trips I would have to take were I to try the entire line!
Judging from the faceplate, I played a Rockerverb amp a few years back. It's what drew my attention to the Orange brand in the first place, although at the time I was playing a Vox AC30 which fit my band better.
Now I can finally get rid of the Vox and explore Orange!
A question: what's the difference between the Thunder and RV series? From my cursory search, it seems like they would be very similar amps.
Thunder/Thunderverb
Rockerverb
OR
They're quite different. The RV has a dirty and clean channel each with full EQ. Thunderverb is a bit darker sounding amp with two dirty channels, one with the usual fmv EQ and one with the shape control EQ. Both amps have reverb, but the Thunderverb adds an attenuator function.GoobyGoober wrote:So, the consensus is the following series:
Thunder/Thunderverb
Rockerverb
OR
http://youtu.be/_DcQRcA03eU
I wouldn't go with the TV200 just because of the ohms and speaker choices. If I had one, I'd run it in 100 watt mode all the time as I don't have a high powered cab, so that might still be an option.
I'd go with the RV100 or maybe the new OR100 but I haven't played it. I did not like the TH30, and I haven't played a TH100, so no recommendation there. But, I would stay in the 100 watt camp if it were me, for that kind of music. If the OR100 has any likeness to the OR50, it would probably hit the doomy fuzziness tone better than anything else, and at 100 watts it would have more arse than the OR50. The OR50 does all of that music well, but I think it would benefit from being a 100 watter. I know with the OR50, no pedals are needed to cover any of that stuff, and do it well.
You don't think running a Thunderverb 200w head into the regular Orange 4x12 cab with a "Power Handling - 240w" would be alright? Obviously you would not be maxing the amp out. Probably never even going past 11 o clock, even for show volumes.ironlung40 wrote:I wouldn't go with the TV200 just because of the ohms and speaker choices. If I had one, I'd run it in 100 watt mode all the time as I don't have a high powered cab, so that might still be an option.
Users browsing this forum: No registered users and 210 guests
