Have you ever used a preamp pedal this way?
Posted: Thu Aug 02, 2012 2:07 am
I have recently been loving the way I use my Tech 21 Blonde pedal with my OR15.
Since the OR15 is a single channel amp I was always trying to boost the amp into distortion with my other pedals. But what I really wanted was the pure tone from the amp without much coloration. I was able to do that by going from clean to mild crunch and from light overdrive to distortion by using conservative settings on my pedals, but I really wanted to go from clean to all out distortion. So I had a brain storm. I set my amp to the distortion level that I wanted and set the Tech 21 Blonde clean with the volume low (but close to unity), gain around 9 o'clock and the character just before noon. It is a fender simulator so it does cut some of the mid range (which can be compensated a little with its mid control) and makes it sparkle a little more than the normal amp clean. But then when I kick it off I get the screaming distortion I wanted. I really like the clean sound of the amp by it self but this is a compromise for now. Its using the pedal the reverse of how most people use them but it seems to work just as well.
I was just curious as to how many other people have used their preamp pedals in this way for a single channel amp and if you liked it? (sometimes mid strum I'm looking to kick it over so using the volume knob is very hard to do)?
