Wooden Picks...
Wooden Picks...
Just bought two after hearing they are supposed to be great: a rosewood one and an ebony one. I have to say I'm pretty impressed with the amount of difference it makes in the guitar's overall tone. Much warmer and I seem to be getting faster now that I'm getting used to the thicker pick (I've been playing Tortex 0.73s for about 22 years exclusively). Kinda like a fingertip sound if I had to describe it. I don't think it would sound too great on acoustic guitars, but the ebony one especially sounds fantastic with my SG. It kinda rounds out the sharp edges on the thinner strings sound, but focuses the bass strings. I will say that fast strumming (funk style) is a bit challenging now but I think if I had a thinner ebony pick it would be just fine (the ones I bought are fat as sh*t and have a profile-groove for your thumb. All in all I recommend trying them because I personally never thought that there would be such a noticeable feel and sound difference.
Re: Wooden Picks...
Big thick ebony pick with a groove for the thumb? Where did you get this? What's the company that makes them? I bought a pick like that years ago and loved it, but I have no idea where it is now.
Re: Wooden Picks...
That's pretty interesting that they can noticeably thicken up the sound of the higher strings - that's exactly what I want. Do you have any idea at this point how durable they are compared to conventional nylon or tortex picks? I really like how well Dunlop nylon picks hold up, so I'd be a little hesitant if wood picks wear down a lot faster.
Re: Wooden Picks...
Talking to friend recently who plays the viola and they can spend a fortune for just the right bow and the bow can change their tone completely. In some ways the same is true of picks. So tone may be in the fingers and the pick.
Re: Wooden Picks...
I have no idea how durable they are for sure....however after an 8 hour shift of playing the crap out of it there is no wear to be seen on the tip. The picks are from John Pearse I think. I figure you could get a piece of ebony and cut them yourself too for less money, and maybe make them tthinner if you like (at the risk of it snapping in half).Randy Bass wrote:That's pretty interesting that they can noticeably thicken up the sound of the higher strings - that's exactly what I want. Do you have any idea at this point how durable they are compared to conventional nylon or tortex picks? I really like how well Dunlop nylon picks hold up, so I'd be a little hesitant if wood picks wear down a lot faster.
Re: Wooden Picks...
Update:
I've just gotten to work and been playing it through my RV50C (MKI) and I've noticed a fairly significant drawback: the bottom end has softened considerably. You know how when you use a Tortex pick, the string will "snap" out from under the edge of the pick and make riffage fairly chunky? Well now it's perfectly smooth and round with distortion and not as good. Maybe that has to do with the fact that my ebony pick is fat and roundish at the tip. I might have to look into getting a thinner one and see if the "edge" is back otherwise I don't know. Sounds great on leads though on the thinner strings.
Update again: I think it really is to do with the thickness of the pick. Mind you the RV50C MKI is kinda soft anyway...I'll have to see how it sounds with my MARSHALL VINTAGE MODERN that I'm getting on wednesday!
Re: Wooden Picks...
You're right it probably is the thicker pick moreso than the material.
I'm a big believer in thicker picks AND thicker strings (w/ a wound G). Just a fatter tone IMHO. Try the purple Tortex (1.14) I found they really added to my tone when I switched to them from a Tortex green (.88?). Less of a "chirpy", scratchy sound and more of a beefy, more defined sound. That chirp I was getting on thicker gauge strings with a thinner pick would drive me insane.
I use the purples with GHS DYM .013-.056 and have been really happy with the setup on my LP's. That wound G IMHO is really crucial. C# "standard" tuning, post metal kind of stuff. Takes a few days to build up a bit of extra strength.
Obligatory YMMV.
Obligatory YMMV.
Rockerverb 50 MK I head
Miscellaneous PPC212's and PPC412's
Gibson Satin Ebony Les Paul Studio
Gibson Fireburst Les Paul Studio
Re: Wooden Picks...
i can only use oxygen free NOS pics - it's like lifting a blanket off of a blanket
Re: Wooden Picks...
I have an ivory pick. I dig the hell out of it. I also like the orange tortex picks.
Re: Wooden Picks...
Van Cleef wrote:i can only use oxygen free NOS pics - it's like lifting a blanket off of a blanket
Re: Wooden Picks...
I always wear a cheap metal pick on a necklace around my neck. A good friend noticed this and had a custom made 9 carat gold pick made for my 21st birthday. I've never worn it and I've never played it, out of fear of damaging it or ruining my guitar!
Amp
Orange Rockerverb 100
Cabinet
PPC 412 HP 8
Cabinet
PPC 412 HP 8
Re: Wooden Picks...
i used to play bass with a zippo - true story
Re: Wooden Picks...
I often put a flathead screwdriver under the strings on the 2nd fret and play slide with a zippo.Van Cleef wrote:i used to play bass with a zippo - true story
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
Re: Wooden Picks...
I play slide with just my fingers. Fretless bass!
On picks though, while I've never tried wooden or metal ones what I do do is use various different thicknesses for guitar. If you buy a range of guages of the same type plectrum you'll find you get very different tones - often all usable. Lighter ones sound more toppy and are great for jangly strummy stuff. Heavier ones get you more real depth of tone and volume and are better for single note stuff or for more grunge. Differences are really dramatic on an acoustic - you can make one guitar sound like several different ones depending on which pick you choose. The effect is very similar to using radically different string guages, it is cheap and easy, and I'm honestly surprised that more people don't do this.
Re: Wooden Picks...
That's what I love about bass- no pick required. Of course, if you're playing Motorhead the requirement returns.
mmmmmm drop
Guthrie Matthews Method
Users browsing this forum: No registered users and 264 guests
