Rockerverb 100/Thunderverb 200 vs TH100
Hi all Orange experts,
I'm looking to get me a new amp. I have a TH30 but it is not loud enough for rehearsal. I can't match the drum level.
I've been looking at Rockerverb 100 and Thunderverb 200. I very much like til distortion and controls in the RV, but it has not the depth and clarity of the TV i like. The perfect tone for me is a combination of those to amp. I play in a post/black metal band, so I need a good high gain with clarity i cords and bassy depth.
Maybe the TH100 is more in my taste? Is it more bassy and clear in it's tone then the TH30?
It should be mentioned that I haven't tried the RV or TV with the rest of my band, only at a store
Re: Rockerverb 100/Thunderverb 200 vs TH100
IllDuce wrote:Hi all Orange experts,
If all u need is more of the TH30 sound, then I'd automatically say TH100. But, that is about all I can muster on this one. I take the "more bassy and clear in it's tone" to mean more headroom and the TH100 will definitely have more of that.
I can't imagine the TH30 not being loud enough for a rehearsal though, as I know the rocker 30's will keep up with a loud drummer. Is your amp healthy?
choice 2:
tell the drummer to shut up.
choice 3:
make sure the cab isn't just pointing at your feet.
choice 3:
Dark Lord of the Schwartz
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2016 Gibson LP Standard
2012 Gibson LP Classic Custom
2017 Gibson Firebird Studio T
2018 Taylor 616CE
AD15/12
AD30TC
AD50
AD140
Thunderverb50
2018 Taylor 616CE
I know that the TH100 is louder and it has more headroom, but the question is more about does the TH100 have more clarity and more bassy sounding, like TV200?!
We have 2 guitarists in the band and we both have the TH30 and neither of them is loud enough. I have also tried to swap all the tubes incl. power tubes. But also the the clarity is a bit of an issue, maybe it's too gainy?!
As I said... The ultimate amp is a hybrid between the RV100 and TH200, but that doesn't exist The alternative is to buy both of those amps and a PPC412HP-8 and make a custom footswitch that switch both amps at once, but is an very expensive project...
My cab is raised about 90 cm from the floor. I wouldn't mean it pointing at my feet
A 100w amp will have more bass than a 30w generally speaking, and the added headroom will allow more volume with a "clearer" or "cleaner" sound so it might work. AD140 maybe?
Dude, seriously, if two TH30s aren't loud enough to overcome your drummer... get a new drummer.
I play a 30watt el84 amp and it could be used to blow my drummer's head off from 10 meters if I was so inclined.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
baytamusic: What I have heard from youtube the AD140 doesn't have the gain I need. And maybe your right about the 100w thing thanks... I have to try it, if it's possible... But I can't return it if it's not like I hoped... I can only play it in the store
OU818: Don't know what to say... I'm not lying... We had hoped that 30w would be enough, but it's not... We both are looking to buy new amps. We have to turn the volume op to about 2 o'clock and it breaks to much and doesn't sound good...
You're describing headroom issues, if you're getting too much breakup then you want more headroom which equates to the bassier clarity comment you made.IllDuce wrote:baytamusic: What I have heard from youtube the AD140 doesn't have the gain I need. And maybe your right about the 100w thing thanks... I have to try it, if it's possible... But I can't return it if it's not like I hoped... I can only play it in the store
You say 2 o'clock, but are you maxing out the master volume and THEN turning your preamp gain up to the desired levels when on the dirty channel?
Mmh, the clean channel of the TH30 doesn't have much headroom, fromwhen I tried it, I couldn't see myself playing it "clean" with a drummer. It will get that old school break up, quite fuzzy - great for 60/70s rock, but not sogreat for clean parts IMO.
If you like the overal tone of the TH30, but just need clean parts with no hint of break up at all, then the TH100 shoulddo the trick.
Yes, I set the volume of the gain channel to the level to match the volume of the drums (about 2 o'clock) and set the preamp gain at about 1-2 o'clock to get the gain i want, and it doesn't sound that good. If i turn the gain down I'm not getting the feed and sound/tone i want.ironlung40 wrote: You're describing headroom issues, if you're getting too much breakup then you want more headroom which equates to the bassier clarity comment you made.
The headroom of the gain channel is also an issue, after my opinion. I like the overall tone of the TH30, but it's not clear or bassy. But would you say that the TH100 could be a good RV/TV hybrid candidate?Les Paul Lover wrote:Mmh, the clean channel of the TH30 doesn't have much headroom, fromwhen I tried it, I couldn't see myself playing it "clean" with a drummer. It will get that old school break up, quite fuzzy - great for 60/70s rock, but not sogreat for clean parts IMO.
Headroom is a perfectly cean tone before any sign of overdrive/distortion.
In respect of your dirty channel, I assume you are disappointed with the clarity/articulation of your tone at higher gain settings? Do you want your tone to be tighter? And have more bass to it?
I have never tried the TH100 - it should be the same amp as yours, but the with more low end because of the higher wattage. However it may well be that its overall clarity/articulation is about the same as your current amp.
I want the clarity and lows/bass of the Thunderverb, but I think it's missing some gain. I don't need/want a tighter distortion. It's not that tight metal i'm playing. The music i'm playing is more Cult of Luna, Isis and The Ocean.Les Paul Lover wrote:In respect of your dirty channel, I assume you are disappointed with the clarity/articulation of your tone at higher gain settings? Do you want your tone to be tighter? And have more bass to it?
I'm not sure if the TH100 will help you. It will have more low end for sure, but can it pull as much low end as the TV series, i'm not sure. The TV50/200 have dedicated transformers to have so much low end.
At this stage, the TV200 and a boost for extra gain might be the better option? At least you know that it has the low end and clarity you want.
The rockerverbs are capable of plenty low end too - though i find that loads of bass on my RV50 can be detrimental to overall articulation. Bloody good though!
I think you are right about the TV200... I had just hoped the TH100 was something for me, with the lower price...
What booster would be the one to go with then?
What sort of volume did you get to try the 200 out at? Practice/gig levels?
Why do you want a boost? More gain? Compression? Cut?
Thunderverb 200
Rockerverb 50
PPC412hp8
PPC212cb
Les Paul Custom
American Standard Tele
Users browsing this forum: No registered users and 219 guests
