Orange rocker 30
Orange rocker 30
Right i just got me an orange rocker 30 and i have a question.
I have band practise tomorrow and i didnt get a footswitch with it, but i have a jet city single footswitch.
My question is will the jet city footswitch work with the rocker 30 and will it damage it if i use it with the rocker 30?
Re: Orange rocker 30
I use a marshall one with my rocker 30.Iit hasnt hurt it. As long as its just a single foot swich it should be fine.
Yer it is a single footswitch, just a normal footswitch to change between two channels.
So it should be fine to use yep? if its not compatable will it hurt the amp at all?
Don't see it being an issue. Orange use a basic switch circuit. You'll be fine.
ok cheers for the help
- Orange Expert
Congrats on getting one of the finest 30 watters around. Hope you enjoy!
And pretty much any single channel change footswitch should do the job.
Gordon Smith Galaxy
Gibson Les Paul Classic
Faith Jupiter Jumbo Acoustic
Orange Rocker 30 HD
Orange Micro Terror
Orange PPC 212 OB
Lead
Plectrum
Attitude
Sorted!
Gordon Smith Galaxy
Orange Rocker 30 HD
Orange Micro Terror
Orange PPC 212 OB
Lead
Plectrum
Attitude
Sorted!
cheers man, first impressions are great, im loving everything about the amp tomorrow will be the real test tho as im putting into a live band situation. i have a feeling it will fair well. such a great sounding amp.
+1 . Marshall one cost about a third of Orange and does a fine job!cica1066 wrote:I use a marshall one with my rocker 30.Iit hasnt hurt it. As long as its just a single foot swich it should be fine.
all you need is a latching type footswitch. it will either work or not work as some switches are non-latching. it will not damage the amp if it is the wrong thing. welcome to the rocker 30 club! it's a nice place to be
I've got love to burn!
-Orange Rocker 30, 1x15 Glaswerks Cab, Emminence Big Ben.
-2010 LP Trad Pro, 2002 Gibson FB VII.
-Celestial Effects Scorpio, Aquarius, Virgo, Taurus, Sinna-a Wah, Line 6 MM4, TC Alter Ego.
I had a Dual terror and a Jet City JCA22h at the same time. When I first got the JCA I didn't want to unwrap the footswitch.....tried using the Orange and it didn't work. Not sure how the opposite will be though.
Hey cheers fort he help guys, the footswitch worked fine.
Just for the record this amp is soo gd! after using it at practise i realised just how good it is.
Its just so versitile for a simple amp. And really loud for a 30 watt amp.
Strange thing is our other guitarist has just brought a rockerverb 50 mk1 and my amp was both louder and i think it sounded better too.
Anyone know why it would be louder than a 50watt amp? its not got stock tubes soo i thought maybe its got some pretty nice tubes in it? or is it cause its class a and the rockerverb 50 is a/b?
The R30 is excellent for cutting in a mix. Some people perceive volume differences when it is really just a matter of EQ voicing. Also, what kind of speaker and speaker cabs were you using? That will also affect sound projection quite a lot.
Aww could be but i thought a rockerverb 50would be too.
And i forgot about the cabs.
i was using my orange 2x12 ob and he was using some hayden 4x12 the rehersal studio had already set up in the room.
Yeah, they are killer 'little' amps. Congratulations on yours!BillaBoB wrote:Hey cheers fort he help guys, the footswitch worked fine.
Reason it can easily hang with (or even hurt) a RV.50 is that the RV is a more compressed style amp than the very dynamic Rocker. While the R.30 may only sustain around 30W RMS, (= continuous average power output), it can put out much higher momentary peaks than you'd normally expect from a 30 watter. And it is the attack of a note which we hear as making it loud.
Also... cathode biased amps (like the R.30) have a fairly unique sort of dynamic compression which really does make an amp sound louder. This is a very bold amp with a wide dynamic range and you can hear that easily. (This is exactly why I compare it's feel and dynamics to the very lively OR series vintage Oranges. It is much closer to them than any other of the modern Oranges I've played!)
Also... the Mk.1 RV.50 with its 4 x 6V6 valves probably can't quite sustain a true 50W RMS output due to the valves themselves running out of steam. (It'll be pretty close, but a true 50W RMS clean would be pushing it.) Two good EL34 valves are easily capable of that though, so in the case of the R.30 the actual limiting factor to the sustained output power is something other than the valves.
These are probably the biggest factors technically.
Damn good explanation.....
Users browsing this forum: Google [Bot] and 241 guests
