Help Me Think of Mods For My Strat...
Re: Help Me Think of Mods For My Strat...
I like the idea of the push-pull mid boost. I'll add that to my list.
As for the tremolo, it's a 6 pole version. Its also a left handed model, which increases the cool factor of my Strat (you can see it in my signature if you look close enough). Could a lefty tremolo on a right handed guitar go out of tune easier than the normal configuration?
Fender Stratocaster || Les Paul || Garrison Acoustic
Orange Dual Terror
You need to check out Rothstein guitars. I modded my Fender Jazz bass with one of his kits and it is absolutely killer. You can do mid-boost, varitone, mid-cut, active, passive, whatever your heart desires.
mmmmmm drop
Guthrie Matthews Method
did you change the nut at all?
If you've got a lefty nut righty stringed guitar, your problem is there.
Pop the nut out, and stick the other way around. Your problem should be solved. If it solves it, add a tiny drop of super glue - though string tension alone should keep it in place.
Mechanicaly, nothing should prevent that tremolo working perfectly upside down.
i believe the upside trem is an srv thing isnt it?
some cool ideas, i've always fancied modding my strat... having a master tone and something else? i might have to take some inspiration from some of the suggestions!
Will.
The mod I did on my strat was to rewire one of the tone dials as a blend dial. So... master volume, master tone & blend. When in positions 1 or 2 it mixed in the bridge, progressively, and then when in 4 or 5, the neck pickup.
Made for a really versatile range of sounds...
Want a humbucker or boost sound, grab a pedal. Or do it old school and have your "normal" settings with the guitar volume dial at 80%
I've been trying to hold off posting this because it adds nothing to the conversation...
But a truly awesome mod that would have people talking about you forever more would be a button which, when pressed, sounds a foghorn and releases a swarm of live bees into the audience
Kerry
Love the foghorn!!!!!!!
Them poor bees though. Unless the pub you're playing has a hell of lot of flowers needing pollinating...???
How about a 'super killswitch' designed to short out all electronic equipment in the building? A good way to end a show if it's not going to plan
Teddy
I play an AD30TC
I play an AD30TC
How about just messing around with different caps and wirings, treble bleeds and so on? At least on a LP it makes a big difference.
Gear at the moment:
Gibson LP 1955 RI
'76 Gibson LPC
Haar 'Blackie' strat
'65 Tremolux
Orange R30
'72 JMP SB
'82 JMP 2203
50w custom plexi (For sale)
HW-cabs
...and that's about it, for now.
Gibson LP 1955 RI
'76 Gibson LPC
'65 Tremolux
Orange R30
'72 JMP SB
'82 JMP 2203
HW-cabs
Upgrade the trem block for a big brass block. Add sustain and warmth.
Tone is everything
Put a camelbak pouch in the rear cavity, fill it with whisky and run the tube around your strap.
Can't believe I never thought about that before...
Freaking brilliant!irish_admiral wrote:Put a camelbak pouch in the rear cavity, fill it with whisky and run the tube around your strap.
Users browsing this forum: Google [Bot] and 164 guests
