Is the Dark Terror tight enough to play things like this?
thedarkoceans
Post by thedarkoceans » Sat Oct 29, 2011 6:29 pm
hey guys! i really really need your help.is the ODT tight enough to play really fast/technical metal?what do you think? help me guys.
tdo.
jason41224
Re: Is the Dark Terror tight enough to play things like this?
Post by jason41224 » Sat Oct 29, 2011 10:42 pm
chances are, we will all say yes, but the real metal folk (yourself probably included) will disagree sharply. so i'd say no (though i could probably coax some nice metal tones out of there).
listen to Rob Chappers demo on Youtube. i think it does the sound justice. in it, he mentions that it's not really a full on metal amp, but it does metal okay.
Jason
too many pedals
kmlabs
Orange Expert
Post by kmlabs » Sun Oct 30, 2011 9:54 pm
The Dark Terror isn't a full-on metal amp? Are you SURE?!
Having replaced my Rockerverb with a DkT, I'd say yes, the Dark Terror will do fast/technical metal, and do it well. It has more gain that you could ever need, and the shape control takes it from a very middly sound through to a full-on scooped sound; if you can't find a decent metal sound in there somewhere then there's something wrong.
Kerry
jason41224
Post by jason41224 » Sun Oct 30, 2011 9:58 pm
^like i said, most people on here (myself included) would say that it could do metal just fine. but kids looking for a Peavey 6505 clone (coughcoughbadmonkeycoughcough) will always b!tch about how it's not tight enough.
Jason
too many pedals
Icarus
Orange Expert
Post by Icarus » Mon Oct 31, 2011 5:55 pm
I imagine through a decent 4x12 it would do the job but maybe not through a 1x12 or an open backed 2x12.
If you dig orange tones but want something with more gain, you'll love it. If your dream is a 6505+ but cant afford one, get a bugera.
Thunderverb 200
Rockerverb 50
PPC412hp8
PPC212cb
Les Paul Custom
American Standard Tele
hellagnar Brosevelt
Orange Expert
Post by hellagnar Brosevelt » Mon Oct 31, 2011 11:33 pm
When has rob chappers played a Dark Terror?
http://blackdots.bandcamp.com/" onclick="window.open(this.href);return false;
jason41224
Post by jason41224 » Tue Nov 01, 2011 6:22 am
http://www.youtube.com/watch?v=kGAunX1EZ-U
as seen on here a couple of weeks earlier
Jason
too many pedals
jason41224
Icarus wrote:If you dig orange tones but want something with more gain, you'll love it. If your dream is a 6505+ but cant afford one, get a bugera.
this.
Jason
too many pedals
Post by Les Paul Lover » Tue Nov 01, 2011 7:32 am
I've seen Kerry (KMlabs) play his dark terror live once and once at practice, yes, it does tight metal - wth tha Orange flavour.
Wolfe
Post by Wolfe » Tue Nov 01, 2011 6:43 pm
I tried the dark terror at my music shop, it wasn't tight on it's own. I plugged in a hardwire cm-2 and set it to be a clean boost... it was fairly tight, sounded okay for tech/prog, I guess
I would think you would get better results with an eq pedal and a compressor. with the eq pedal you can cut the frequencies that make it sound muddy.
the compressor will make it more in your face and punchy.
this amp sounded fairly saturated, for tech stuff you do not want much saturation!
however, this amp is very good for thrash (pantera, metallica...)
for tech stuff, don't get this amp! (unless you are prepared to spend more on pedals or what ever to make it sound right, than the amp itself!)
remember, metal tone is NOT all about gain... in fact, the less gain you have, the clearer and tighter the sound
Wolfy'
bradley9in
Post by bradley9in » Tue Jan 17, 2012 7:12 pm
@kmlabs Since you own a Dark Terror, I have a question. Does the amp give off a sharp hiss? I've heard some people complain about that. Also, would you recommend the Dark Terror for Chevelle and Tool type sounds? Thanks man!
Dollywitch
Post by Dollywitch » Tue Jan 17, 2012 7:59 pm
It really depends what cab you use it with too. Using the same cab as you would a regular Orange might not always be the best idea. If a cab isn't good for metal, it's not good for metal. Though the PPCs should generally be fine for most genres.
Stringjunkie
Post by Stringjunkie » Tue Jan 17, 2012 10:29 pm
With the right pedals this amp is capable of about any metal tone you can think of. I use EQ>delay>Decimator in the loop and this thing kills.
Foef
Post by Foef » Wed Jan 18, 2012 11:46 am
If an orange is not tight enough, maybe your technique is lacking????
Grtz, Bert.
Squier 15 (1988)
Mesa/Boogie F50 (2005)
Orange CR60C (2014)
Stringjunkie
Post by Stringjunkie » Wed Jan 18, 2012 3:00 pm
Foef wrote:If an orange is not tight enough, maybe your technique is lacking????
Grtz, Bert.
THIS!
