Hi all, it's been a while since I've posted around here, been really busy playing. How's everyone been? My question is about the Vox AC30 C2X, and a Palmer PDI-09 direct box. To hook the palmer up to the amp, if I plug the palmer into the extension plug, and keep the impedance switch at 16 ohms (the speaker's impedance), would that be right?
This is taken from the palmer manual:
If your amplifier has multiple speaker outputs then these can also be used to connect to The Junction. Since the PDI-09 does not load the speaker output, no change will take place in the amplifier’s impedance adjustments. If your amp has a variable impedance switch, it should be set at the impedance of your speaker/speaker cabinet or external load box.
Sounds right to me, but I just wanted to make sure since I wouldn't be using the thru jack on it like I would be hooking up a head and cab. Thanks!
Question about Vox AC30 and palmer box
Re: Question about Vox AC30 and palmer box
It looks like it's essentially a passive DI, with some cool filters, that also accepts speaker level. My Radial JDI is very similar. It doesn't look like there is a simple way to run this DI inline on the AC30. You may be better off getting someone to wire you a jack for it that keeps the DI inline where no impedance change is what the transformer should see. The way the amp is configured now is for an additional load. Another way to do it would be run to run an extension cab and have the DI run inline with that and connect to the appropriate jack for the impedance of the extension cab.
mmmmmm drop
Guthrie Matthews Method
I've thought about running another cab, but I'd really like to mic the speakers in the amp, and run along side it. Been trying to call Palmer today and find out, with no luck. Looks like a trip to the tech!
For anyone that may be interested, Palmer just got back with me and told me to connect the box to the extension jack using a speaker cable, and that would do it.
Users browsing this forum: No registered users and 286 guests
