orange th30 has less mids than the rest of the product line?
after playing on a rockerverb 50 I can't help thinking that the th30 has got less mids than it, It just seems to have alot more boomy bass that the rockerverb so I am not going to get a gt-od because it doesn't cut much bass and add as much mid range so will not make much difference at all, I'm going to get an od808.
Wolfy'
Re: orange th30 has less mids than the rest of the product line?
Can I be the first to mention a 'mid hump'?
Teddy
I play an AD30TC
I play an AD30TC
I used to like the high hump when I was younger. Now it's too weird.
Not if you get the angle right.baytamusic wrote:I used to like the high hump when I was younger. Now it's too weird.
-Joe
My mother wears army boots.
RV50 mkI
AC30 combo
Hot tamale.
RV50 mkI
AC30 combo
Hot tamale.
I was more thinking about a "state of mind".misterMagoo wrote:Not if you get the angle right.baytamusic wrote:I used to like the high hump when I was younger. Now it's too weird.
I find a small step ladder is good in these situations.misterMagoo wrote:Not if you get the angle right.baytamusic wrote:I used to like the high hump when I was younger. Now it's too weird.
Teddy
I play an AD30TC
I play an AD30TC
I've owned both. I don't think it's a case of having less mids, more of the fact that the entire EQ is set-up differently. With no Treble, Bass and Mid knobs to adjust your stuck with just the shape knob which adds or cuts the mids. Rockerverb has a fully adjustable EQ. You'll understand more if you compare a Rockerverb EQ, a TH30 EQ and a Tiny Terror EQ at the same time. They're all Orange flavoured and probably have a similar balanced EQ setting to one another somewhere on their dials. Mid-hump.Wolfe wrote:after playing on a rockerverb 50 I can't help thinking that the th30 has got less mids than it, It just seems to have alot more boomy bass that the rockerverb so I am not going to get a gt-od because it doesn't cut much bass and add as much mid range so will not make much difference at all, I'm going to get an od808.
Or one of those special cushions.Le Chat Noir wrote:I find a small step ladder is good in these situations.misterMagoo wrote:Not if you get the angle right.baytamusic wrote:I used to like the high hump when I was younger. Now it's too weird.
-Joe
RV50 mkI
AC30 combo
Hot tamale.
RV50 mkI
AC30 combo
Hot tamale.
this topic seems somewhat familiar....
Orange AD30TC, Rickenbacker 360, 52RI Tele
It's probably due to a lack of iron.Bandeapart wrote:this topic seems somewhat familiar....
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Ernie Ball Stingray 4H
Rickenbacker 4003
Gibson Midtown Signature
Gibson Thunderbird
Gibson Nikki Sixx Thunderbird
Gibson Les Paul Bass
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
it's probably just my imagination though, it's just I got home and played my th30 after playing an rvk50 it just seemed to have an ever so slightly scooped tone
Wolfy'
Fixed.OU818 wrote:It's probably due to a lack of iron maiden.Bandeapart wrote:this topic seems somewhat familiar....
I'll probably go buy a Tube Screamer now that I fixed your quote. That is, unless someone recommends one, in which case I'll say that I'm buying something else entirely to throw everyone off the scent. I actually have bought seven already though. I won't buy an EQ pedal because none of them come in lime green.
I think you should try a Mid boost like a Bad Monkey pedal by Digitech. They aren't very popular but I am sure you can find one somewhere near you.
Orange Gear:
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
AD200B MkIII
OBC810
Non-Orange:
Bergantino NXT212
Bergantino Forte D
Woogie Lessie
Laney DBV-410
Basses:
Rickenbacker 4003
Gibson Thunderbird
i couldn't live without a Digitech Bad Monkey. i'm in the process of purchasing every one in the state. great mid hump. really makes my thunder 30 sound like it's two mesa's being tracked in a fancy studio. all in the comfort of my mom's basement.OU818 wrote:I think you should try a Mid boost like a Bad Monkey pedal by Digitech. They aren't very popular but I am sure you can find one somewhere near you.
strymon el cap
tc polytune
apogee one
harpoon hefeweizen
strymon el cap
tc polytune
apogee one
harpoon hefeweizen
MXR 4 band EQ pedal... it was made for the TH30 IMHO
Users browsing this forum: No registered users and 310 guests
