Wow, lots of good ideas here.
Do the Apex switches work just like the Orange; two 1/4" inputs, no power required, LED lights when amp is turned on?
jamison162, does your switch work this way as well?
Thanks for all your suggestions?
- Ryan
Failed Orange Footswitches???
Re: Failed Orange Footswitches???
PRS Custom 24 (Whale Blue)
PRS Custom 24 (Black Cherry)
PRS SE Singlecut (Black)
Orange Rockerverb 50H (Live Rig)
Orange PPC412 Cab (Live Rig)
Orange PPC112 Cab
Line 6 Vetta II
http://www.whitehouseeffectband.com" onclick="window.open(this.href);return false;
Orange PPC112 Cab
Line 6 Vetta II
yesrclangelan wrote:Wow, lots of good ideas here.
- Ryan
Mine has a single stereo 1/4" jack. I made a cable out of Canare XLR (Star Quad) to carry both signals to the amp. A single 1/4" TRS plugs in the footswitch and the cable splits at the amp end to 2 x 1/4" mono plugs.rclangelan wrote:jamison162, does your switch work this way as well?
- Ryan
If you like the housing and have no problems with its size, the cheap way would be to just buy a new switch for $3-$5 and solder it in there. I'm not 100% sure of the pin spacing of the factory PC board, but I bet you could make either of the DPDT latching stomps on this page work:
http://www.smallbearelec.com/Categories ... 9&total=67" onclick="window.open(this.href);return false;
PS- the circuit doesn't require a DPDT, an SPDT or SPST will suffice if you can find one cheaper and you're not planning to use the existing circuit board. Just make sure it's latching.
In the FS-1 project, can the resistor be deleted?
If you don't want an LED, yes. I replied to your post in the technical forum with more info.rokdad wrote:In the FS-1 project, can the resistor be deleted?
Users browsing this forum: Google [Bot] and 363 guests
