I agree with you but if a person wants 3 (or 4 counting another clean sound) sounds that are:a.hun wrote:Clean cut though. That does change the volume. Why a couple of us have mentioned it really...brianr0131 wrote:Clean boost, Dirty boost either way it's relative. This method will work well if you have your gain knob around 2 o'clock (on my amp) or lower. Otherwise, it will just add gain and almost no volume. If someone likes their rhythm dirty sound to be real dirty, there's not much they can do on the R30 Dirty Channel for solo boost. It's just like the 100 threads about solo boost on a TT....anything you add in the front will just saturate the preamp section if your gain is set pretty high.
1 Clean
2 High Gain
3 High Gain Louder for Solos
It will never work with an amp that has no effects loop because you are basically altering the input section only whether you use a clean boost or a clean cut. You're basically adding DBs or subtracting them but from the input stage only.
You can get:
1 Clean
2 Med Gain
3 High Gain (louder than #2)
with a great amount of success though.
I am just pointing out that without effects loop all you are noticeably changing is the input section.
If someone wants a real dirty and real dirty louder sounds then the TT or R30 will never give that without mods.
Someone who NEEDS this has to pick another amp or use the clean channel to get one of the dirty sounds.
