Orange 4x10 GUITAR cab?
I've heard that they're releasing a new Orange 4x10 for guitar. Now, after being on this forum for a while, I've noticed a bunch of people that really know their stuff. And I love it. Randy Bass, if I remember correctly, spoke of the ever elusive Orange 4x10 GUITAR cab that will be coming out.
I wonder if it will be roughly the same dimensions as the PPC412 so you can stack it underneath? I need more information on this cab! This is too cool to not come out!
http://www.myspace.com/wreckmusic" onclick="window.open(this.href);return false;
http://www.facebook.com/bigblackheartattack" onclick="window.open(this.href);return false;
Les Paul>TU-3 Tuner>PS-5 Super Shifter>DD-7 Digital Delay>NS-2 Noise Suppressor>Rockerverb 100>PPC412
Re: Orange 4x10 GUITAR cab?
I've yet to see concrete specs (or a photo), but you can plan on the 4x10 guitar cab being smaller than the PPC412 by a fair measure. That's one of the major reasons to make a 4x10 cab. It will likely be the same width as the PC212-OB or smaller. My M*rshall 1965A cab is 24" x 24", which should give you a good idea of the minimum dimensions to expect from the Orange. The 1965A has Celestion G10L-35s in it and sounds very good with the TT. It would be a bit lacking in bass response for the Rocker 30 IMO (haven't tried it).
i would be all over an orange guitar 4x10 like biggie smalls is all over a blunt.
valve.(((J0HN)))Resident village idiot
and some tech helper type said, "Gee, Mr Atkins, that guitar sure sounds fabulous!" Chet put the guitar on it's stand and said, "Well, how does it sound now?"
Do you mean that you would lay motionless on top of one if someone dug up your grave and put one under your corpse ?professor plum wrote:i would be all over an orange guitar 4x10 like biggie smalls is all over a blunt.
They show it off a bit on the namm video. "Much smaller so u can throw it in the back of the car" also made overseas to keep the price down. And I really wouldn't be concerned with a lack of bass response at all. Ever played a bassman?
Thunderverb 50,
It's more of an issue with the way Orange voices some of their amps. The R30 seems to need all the help it can get from the speakers to reproduce lows (unless you crank it). The Bassman has great low end in large part due to the design of the amp rather than the speakers. They will probably use Celestions with a low-end range around 100Hz in the PPC-410(?), so they will be lacking a bit in comparison to the average 12" Celestion guitar speaker. Some amps will be able to make up the difference better than others, and it won't matter as much for amps like the TT.Y0UNGBL00D wrote:...And I really wouldn't be concerned with a lack of bass response at all. Ever played a bassman?
Or the tv50
Edit: street price of $699. Trying to find the video w the speaker model.
Thunderverb 50,
This retailer appears to have info on it:
http://www.gear4music.com/Guitar-and-Ba ... abinet/CHA" onclick="window.open(this.href);return false;
I am a bit disappointed in the 40kg weight. That would still be a chore to carry up from my basement alone.
Orange PPC-410 Guitar Cabinet - Orange speaker ensclosures, like their amplifiers, are built to last using extremely rugged construction and manufacturing techniques. Every Power Projection Cabinet (PPC) is manutilising 13 ply high density 18mm birch plywood throughout.
More Details:
Ornage's Unique skid design feet help acoustically couple their cabinets to the stage to provide a tighter bass response and full range definition. All Orange enclosures are equipped with Celestion Vintage 30 Speaker units and feature comfortable flush cabinet handles.
Features/Specifications:
Speaker Configuration: 4x10" Celestion Speakers
Power Handling: 120 Watts RMS, 16 ohm
Cabinet Construction: 13-ply High Density 18 mm Birch Plywood
Compact Size
Further Specs:
Dimensions & Weight:
Width: 66cm
Height: 70cm
Depth: 30cm
Cab Weight: 40kg
I hate copy paste specs on sites like this. The 410 obviously doesn't use v30s. I wonder if the dimensions are even correct. (To be fair, all base production 12s are v30 not counting anniversary model, I see what they're getting at)
I'm assuming that the 10s will be the same as the new 10 tt combo? Could be wrong. The ones in the 410 are the ones that "sound like greenbacks"-ade. Forget the model number and couldn't find the video
Thunderverb 50,
if the dimensions are right, it would be the same width as the ppc212ob.....whicht would be a killer stack imo
the price is also not much more than the ppc212ob
does the ppc410 have an opened or closed back?
In the YouTube video, he refers to the G10 40, which must mean the G10N-40, the speaker used in the AD5. I have never heard it in person. I was hoping they would use the G10 Vintage which is more like the V30, but I gather that would be too expensive for the lower price range they seem to be targeting with this cab.
I thought the G10N-40 in the AD5 sounded good - not great. When I tried out the AD5, I also played it through a PPC412 and the difference was more noticeable than I expected. The AD5 is capable of much more bass response than the G10N-40 can handle. I'd buy one if they made a head version, preferably for less than the TT (though it would have to be made in the PRC).
agreed with oddjob on hoping for G10 Vintages
im also a little sad its not english built...
i played through the new orange 4x10 it sounded good through a th 30 head and a PRS.the only real problem its made in china.were the 2x12 is england. this cabnet was at CAPITOL GUITARS ,DOWN TOWN ,ST.PAUL.MINN
i've played through the 410 as well, and it is the same size as the ppc212 open back. it stacks perfectly with that cab, but it wouldn't be as wide as the 412. it sounded good, characteristically 410, if that means anything to you. tight and punchy, but not as full as the 412. i actually liked it a lot. i'm torn between getting that or an emperor to go with my ppc212....
strymon el cap
tc polytune
apogee one
harpoon hefeweizen
strymon el cap
tc polytune
apogee one
harpoon hefeweizen
Users browsing this forum: Google [Bot] and 142 guests
