So my year-old Tiny Terror seems to have developed a problem since my re-location to New Zealand.
I'm playing away and then the volume drops, quite a lot (though I can still hear the sounds), and then kicks in again. Thought it was my pedal board or leads but I've plugged several different leads straight into the head and still get dips in output.
Any ideas? It was sat on a boat for six weeks getting here but it looks and sounds fine (when the sound is all there).
Cheers!
TT Cutting Out?
Re: TT Cutting Out?
loose tube connection somewhere? try taking them out and putting them back in a few times to re-seat the pins
Re: TT Cutting Out?
I'd try new tubes.
Re: TT Cutting Out?
tubes. could be your electrical source too. If your not plugged into a reliable source it could cause that.
Re: TT Cutting Out?
I had this too - is it like a volume drop when you hit the strings hard - like your attack dies before coming back in?
Mine seemed to be a slightly dirty pot - does the problem go away if you move the gain/volume dials?
Otherwise, it sounds like a tube. If its still in warrenty, I'd just get someone to look at it for you.
Dan
Dan
