I have an Orange AD30 single channel and love the tone of the Guitar going straight into the amp, but how will the AD30 deal with some of the pedals below.
I use a fair amount of gain on my amp settings and have no effects loop so im thinking this is going to f**k with the Delay.
Wah
Vibe
Delay
Reverb
Fuzz
Buffer
After playing with just one amp setting and useing the guitars volume to get clean and dirty sounds i would like to have some options, but im scared that some pedals will suck my tone, help me.
PEDALS.
Re: PEDALS.
Depends on the brand/type of those pedals..
I don't use the effects loop on my RV50 and I run guitar > korg pitchblack > vox wah > boss dd-20 > boss OD-3 > fuzz factory > amp.
I admit, the wah sucks some tone, but thats about it.. I barely use the wah though so it doesn't concern me.
Re: PEDALS.
AD30H here
I run delay, chorus, wah and two distortions into the front
sounds great
sounds great
Re: PEDALS.
As per the above.
The 30 doesn't take so kindly to fuzzes unless you have it on a clean setting, but overdrives & distortions it should be fine with. Can't tell whether a pedal will suck tone or not unless you plug it in. Some pedals suck tone, others don't. It's not dependent on type, but usually on the pedal itself...
Stick your delay at the end of the chain. Should be fine there.
Re: PEDALS.
I have:
>wireless>cry baby (wah)>creamtone (overdrive)>carbon copy (delay)>boss chorus>tuner > AD30R
All works fine to my ears...
Mark
Re: PEDALS.
Thanks for the advice guys, so would you say there is no need for a buffer at the start or end of the chain. Because im thinking of getting some true bypass pedals ?
Re: PEDALS.
I have a few pedals and get no tone suck...
Look into pedals and if they're true bypass then when they're not being used they shouldn't effect your tone what so ever!
As for whilst they're being used... You should be able to find info on that too.
Rockerverb50
Orange 2x12
Fender American Tele w/ SeymoreDuncan JB humbucker in the neck!
Orange 2x12
Re: PEDALS.
i wouldnt worry about it too much its more of a perfectionist type of thing if its really bugging u grab or build an effects loop and your set
i own a orange ad140 and a 412 fender super sonic cab
...and a lot of other junk
Re: PEDALS.
I'd only look for a buffer pedal if you start to notice significant signal dropoff.
Re: PEDALS.
I have wireless,Korg Pitchblack,Wizard Wah,Modded TS808,Modded boss sd-1,Roger Mayer uni-vibe,EH Reverb,EH phaser,Boss Chorus and Analogman Delay...All in the front of my AD30Htc No Problems at all
Nick Fender Telecaster (Bigsby),Les Paul Standard, Yamaha SA-700(Bigsby),Battered old Ibanez Acoustic. An ever revolving door of pedals,Orange AD30HTC into Marshall twin cab....The weak link in this signal chain is the one at the beginning..
Users browsing this forum: No registered users and 323 guests
