Keeley Compressor
NiallB
Keeley Compressor
Post by NiallB » Mon Aug 10, 2009 9:51 am
So, I got a 4 knob Keeley a while back (when I was in the states and the exchange rate was 2:1). However, I've recently discovered that it is the source of most of the noise issues in my rig. Any ideas of what to do? Should I drop keeley an email and see what they recommend?
p.s. Here's my chain...
Ernie Ball volume=>Boss TU-2=>keeley=>ts-808=>hotcake=>zvex fuzz=>Boss Dm2=>Boss DD6.
I mean I get the usual slight bump in buzz when I kick on an OD but the keeley just introduces so much it's a real annoyance.
Fender Mexican Telecaster with seymour duncan pickups.
<br />Keeley Compressor:Ernie Ball Volume:Crowther Hotcake:Voodoo Labs Sparkle Drive:Ibanez TS-808 Reissue:Boss DM2:Boss DD6
<br />
Orange AD30TC Combo
mr_william
Post by mr_william » Mon Aug 10, 2009 11:19 am
i think keeley suggests using the comp after distortion...
that way you get less of a boost in the highs... which might help a little... perhaps something to try?...
Will.
irish_admiral
Prince of Orange
Post by irish_admiral » Mon Aug 10, 2009 11:29 am
How's the grounding on it? I sometimes got issues running my Aphex in front of other overdrives.
Orphin
Post by Orphin » Mon Aug 10, 2009 2:36 pm
mr_william wrote:i think keeley suggests using the comp after distortion...
They do?
My Keeley sounds best before overdrive and boost. With the OCD before it, it still works OK, but with the Boner Cloner (Super Hardon) it sounds all muffled up.
David
Knuckle Bones
Post by Knuckle Bones » Mon Aug 10, 2009 2:47 pm
Compressors will add noise...or make noies already there more apparent. It's the nature of the beast.....compress the higher signal and turn up the lower (i.e. noise)
“It's amazing what new strings and a cold beer can do for your toneâ€
Brutalitarian Supremacy
Post by Brutalitarian Supremacy » Mon Aug 10, 2009 3:19 pm
I had the K Comp. and returned it because of the freakin noise issue....
Egoism is the very essence of a noble soul...Friedrich Nietzsche
http://www.myspace.com/wearevarulvorden
NiallB
Post by NiallB » Mon Aug 10, 2009 3:49 pm
Wherever I put it in the chain I get noise. It's freaking loud.
I think I have grounding issues on my tele, I want to get it shielded and re-wired.
I really like the Keeley, but don't want to have to spend loads on getting the noise issue sorted (buying a noise suppressor or a new power supply).
<br />
Orange AD30TC Combo
Orphin
Post by Orphin » Mon Aug 10, 2009 7:24 pm
Brutalitarian Supremacy wrote:I had the K Comp. and returned it because of the freakin noise issue....
Faulty unit then.. Did you immidietly believe that that the pedal would have this noise issue and that thousand users ignored it?
I tried that red Lehle switch once. Noisy as hell, went back with it for a new one. It had the same noise problem, so I gave up, but I hope that both were faulty.
The Keeley compressor doesn't have a noise issue.
David
pedro
Orange Expert
Post by pedro » Mon Aug 10, 2009 9:11 pm
Agreed, I have two Keeley comps and no noise issues at all.....
Drdos
Post by Drdos » Mon Aug 10, 2009 9:23 pm
pedro wrote:Agreed, I have two Keeley comps and no noise issues at all.....
Same no noise issues with my Keeley
Vince
jamison162
Post by jamison162 » Mon Aug 10, 2009 10:00 pm
My friend has a couple of Keeley comps and I have not been impressed with them at all, of course I own a Diamond and there is no comparison.
stevo2112
Post by stevo2112 » Tue Aug 11, 2009 3:05 am
my keeley doesn't add any noise either- alone, before or after dirt pedals. weird that you had issues with it.
Steve
Post by Brutalitarian Supremacy » Tue Aug 11, 2009 4:19 am
maybe your doesn't....but mine sure did...but the only reason I wanted a refund was I ran across an old Ross comp on craigslist(jonesed for one for a long time)...and I paid a helluva lot less for something I wanted a helluva lot more... :D
Van Cleef
Post by Van Cleef » Tue Aug 11, 2009 7:38 am
i got the keeley 4 knob... but i also have an isp decimator
NiallB
Post by NiallB » Tue Aug 11, 2009 8:28 am
Maybe mine's just doing its job really well, and highlighting an underlying problem with either my guitar or pedal boards grounding....
<br />
Orange AD30TC Combo
