You need to upload your photo to an internet webpage (Facebook, photobucket, Flikr etc...) and in your post click the Img button and insert the web link address of the image between the bracketed "img" you'll see after pressing the Img button.Hitlength wrote:Hello! Again, I know this is an old thread, but I don't know where else to turn. I tried to make a footswitch for my new Dual Terror, and it changes channels just fine, but the LED won't light up. I tested the LED with a 9v connected to some alligator clips through the resistor and it was nice and bright. I also tried a Boss FS-5L that also changed channels but it's LED did not light up either. I'm just wondering what I'm doing wrong here. Do I need to use a TRS cable, or should a standard instrument cable work? Or is it possible that there's something wrong with the amp? There was a noticeable clicking coming from the amp chassis when the channel is changed, though I don't hear any popping though the speaker or anything like that. I followed blackcloud45's pictures with one exception... I may be wrong, but his pedal looks like it has the positive side of the switch going to the resistor and then to the sleeve of the jack. The diagrams I see elsewhere show that going to the tip of the jack, which is what I did. When i test it with the 9v, i put the positive on the tip of the jack, and the negative on the sleeve, and the LED lights up nice. SO I assume that the resistor being on the hot side is correct. I put a meter on a standard 1/4" cable connected to the channel jack on the amp and it showed -7.3v. I used the 9v setting thinking that would be the right way to test it, but feel free to correct me.
It won't let me upload a jpeg as an attachment no matter how small I make the pic (it's 27KB)? I don't know how to get a picture up here for all to see. Any ideas?
Maybe try lowering the value of your resistor. I'm not sure how the Dual Terror's switching is wired, but I think it's a bit different than other Oranges because it has to be in Tiny Terror mode on the amp in order for the footswitch to work. What's the voltage on the sleeve and tip of the footswitch cable?
