2 heads into 1 cab
hahahaBandeapart wrote:Or you could try to run 2 heads into a mono cab -
Just please film it and upload the footage to youtube for us.
as fun as that would be to watch when someone else does it.... not for me. hahaha.
That could work for sure. Hmmmm.... Now to find the $3000 for an SLO100 hahahaPopnFresh wrote:You could not close mic the cab, and deal with the splashes from other sources, or get a mono mic mixer and run 2 of your mics into one XLR for the soundboard.
Re: 2 heads into 1 cab
Axess Electronic use to have a Head Spliter thing I think it was called the "HS-2". They dont make it anymore but I use to own one. You would plug you both heads into the unit and run a trs cable up to your pedal board and you could use the footswitch to change between the two different heads. it was pretty awesome.tadaitstyler wrote:Ok. So this would not happen for a long time (unless I came across loads of money out of nowhere) but it would be awesome to run my rocker 30 with a soldano slo100 at the same time, into the same cab. I don't want to do a stereo cab, because micing then becomes an issue. And I want to be able to run both heads at once. I was looking at the Radial Tonebone VT, but it just switches between the 2.
Anyways, it would take me a long time to get that setup, but I think it would sound sick.
Anyone know of a way to do it/a pedal or something to do it?
Amps: 67' AC30 TB
Timefactor, #3 proto MP FGC, Katana, Rat, Joyride, BB preamp, BJF PGC all controled w/Musicom.
Once again, there is a world of difference between a unit that switches between heads - an A/B with dummy load, which several companies make, including the radial units - and something that allows you to run two amps SIMULTANEOUSLY into one cab, which is what the original poster is asking for.musicman_1300 wrote:You would plug you both heads into the unit and run a trs cable up to your pedal board and you could use the footswitch to change between the two different heads. it was pretty awesome.
Teddy
I play an AD30TC
I play an AD30TC
Users browsing this forum: Google [Bot] and 339 guests
